Specific heat for a triatomic gas
In summary, using the equipartition law, the specific heat of a gas containing triatomic linear molecules can be found by using the equation U = (1/2)NkT*f, where N is the number of molecules, k is the Boltzmann constant, T is the temperature, and f is the total number of degrees of freedom. This includes translational, rotational, and vibrational degrees of freedom. If the molecule was non-linear, the number of rotational degrees of freedom would be 3 instead of 2 due to the ability to rotate around multiple axes. The internal energy is only 1/2 the value of kT because it is the sum of kinetic and potential energies, and the expression for internal energy
Titan97
Using equipartition law, find specific heat of gas containing triatomic linear molecules. Will the result be different if the molecule was non- linear? In what way?
According to equipartion theorem, each degree of freedom gets (1/2)kT kinetic energy and (1/2)kT potential energy.
For a linear arrangement,
  • number of translational degrees of freedom is ##3##
  • number of rotational degrees of freedom is ##2## (or is it 6 because the atom can rotate about the central atom or about one of the atoms at the end)
  • number of vibrational degrees of freedom is ##1##
At room T, i will neglect point 3.
My second doubt is, the internal energy is ##\frac{1}{2}NkT\times f##
Why is it only 1/2 the value of kT (which is the sum of kinetic and potential energies as my prof says in one of the slides which i have attached below)?
In the slide, $$U=\frac{h\nu}{e^{\frac{h\nu}{kT}}-1}$$
Why isn't it $$U=\frac{h\nu}{e^{\frac{h\nu}{\frac{1}{2}\times kT}}-1}?$$
  • Bohr Atom and Specific Heats of Gases and Liquids.pdf
Total number of degrees of freedom is 3n.
How did you get that expression?
1. What is specific heat for a triatomic gas?
Specific heat for a triatomic gas is the amount of heat energy required to raise the temperature of one mole of the gas by one degree Celsius.
2. How is specific heat for a triatomic gas different from other types of gases?
Specific heat for a triatomic gas is different from other types of gases because it has three atoms in its molecule, which affects its ability to store and transfer heat energy.
3. What is the formula for calculating specific heat for a triatomic gas?
The formula for calculating specific heat for a triatomic gas is C = (3/2)R, where C is the specific heat, and R is the gas constant.
4. Why is specific heat for a triatomic gas important in thermodynamics?
Specific heat for a triatomic gas is important in thermodynamics because it helps determine the amount of energy needed to raise the temperature of a gas and also plays a role in the calculation of other thermodynamic properties.
5. Can specific heat for a triatomic gas change?
Yes, specific heat for a triatomic gas can change depending on various factors such as temperature, pressure, and the composition of the gas. It can also vary for different types of triatomic gases.
