Speed & Direction of wave
  • Context: Undergrad
  • Thread starter Thread starter mananvpanchal
    Direction Speed Wave
31 replies · 7K views
mananvpanchal
Source cannot push or pull wave because it is not a matter. So source cannot affect speed and direction of wave.
So why stationary observer feels diagonal path of light in light clock?
on Phys.org
mananvpanchal said:
Source cannot push or pull wave because it is not a matter. So source cannot affect speed and direction of wave. [..]
Your conclusion is wrong. The motion of the source does affect the direction of a wave.
Send for example light through a glass fibre, don't you think that the light will leave the fibre parallel to the fibre? Do you think that it can be different when the fibre is in motion? If you do, draw the fibre in close up and draw the light path inside the fibre. You will see that the light is guided by the fibre along with the fibre.
Yes, light cannot leave fiber either it is moving or not. because light travels through fiber by reflecting internally.
By vector physics if motion of the source can affect direction then it can also affect in speed if source emits wave in the same direction of motion.
Vector algebra is used in physics; however the application depends on the theory. In relativity the speed of light is independent of the motion of the source, just like sound. Thus, try to model how the light continues its trajectory when it leaves the glass fibre at speed c in vacuum. You should see that that isn't an issue.
If a stationary source emits some matter then the matter's path would be straight line, but if source in motion emits some matter then the matter's path would be diagonal. So the diagonal direction is propositional to speed of source in motion. The speed of source will affect both speed and direction of matter.
But emitting wave is different scenario. Source cannot affect its speed, so why do it affect its direction? Do you think that sound source in motion can change sound's traveling path?
Please, explain me the glass fiber stuff with some detail. I cannot get your point.
Thanks.
Thanks.
Here you are:
1. Light ray out of glass fibre as seen from a system in which the fibre is in rest:
.i
.i light
IiI
IiI
IiI fibre
IiI
2. Light pulse out of glass fibre as seen from a system in which the fibre is moving to the right:
t=0
I I
I I
I I fibre
IiI
t=1
.I I
.I I
.IiI fibre
.I I
t=2
..I I
..IiI
..I I fibre
..I I
t=3
...IiI
...I I
...I I fibre
...I I
t=4
...i
...I I
...I I
...I I fibre
...I I
Resulting light trajectory without drawing the fibre:
...i
...i
...i
..i
.i
As you can see, the light emerges from the fibre under an angle as seen from the system in which the fibre is moving, such that the light continues straight out of the fibre which is moving to the right. Indeed it cannot be otherwise, just as a bullet out of a gun cannot leave the gun barrel under an angle relative to the gun. Instead the guidance of the moving fibre gives a horizontal velocity to the ray just as a moving gun barrel gives a horizontal velocity to a bullet.
It is obvious if you regard light as a wave. Have a look at this animation
http://www.blatword.co.uk/space-time/wavemove.mpeg
The light source at the bottom is moving, and from the perspective of the initial emission the light seems to take an inclined path to the moving receiver.
@harrylin
Thank you very much for detailed explanation.
But you saying that fiber pushes wave to change its direction, if source can push the wave to change its direction then it obviously can change its speed. Because changing the direction is the property of speed of source, and the property definitely can affect the speed of wave if wave is in same direction of source.
http://www.nasa.gov/audience/forstudents/5-8/features/what-is-supersonic-flight-58.html
Suppose, that plane is on ground with running engines, then its sound waves travels in sphere. But if plane flying with super sonic speed then it creates cone of sound wave because forward waves cannot chase plane, and with upper and lower waves it creates cone. If as you say source can change wave's direction then there is a sound disk not cone.
But as we know source speed cannot affect speed of wave, so source cannot affect wave's direction too.
@Mentz114
Thanks Mentz114
But it will not showing wave in inclined path, because it transmits wave to all direction.
Suppose, if source is stationary in your video then what would be the path of the traveling circle?
You need to be careful about using the word "obviously". A boat, moving through the water, will produce a wave in a particular direction but the speed of the water wave depends only upon the depth of the water, not the speed of the boat.
Because from the moment the light is emitted, the receiver has moved. The light takes a longer path from the perspective of the stationary observer.
Do you think this is not true ?
mananvpanchal, do you know how a beam of light is created? Think of a spherical source and a small aperture (not so small that diffraction is an issue). Can you describe how a brief pulse of light would form a beam in such a system? Then make the source and the aperture move and describe the resulting beam using the same principles. What is the direction?
Only moving boat can generate waves, not steady boat. So direction of boat is the direction of wave. Think about steady source which can generate one directional wave (like LASER).
Think about how its traveling path, and move the source and think how its path. I am not telling that speed of wave is depending on speed of source. My point is neither speed nor direction is dependent of source' motion.
Ok, Source and receiver is moving. There is source at x=0,y=0 and receiver at x=0,y=1.
when source emits light at x=0,y=0. Why light reaches to x=1,y=1? It should reach at x=0,y=1. Who effects the light direction? the source? the speed of source? then why speed of source cannot affects speed of wave? Again I think neither speed nor direction is dependent of source's motion.
Ok, when we think about spherical source then I think so "moving source's wave takes longer time to reach receiver". because if source and receiver is moving to right hand, then left hand part of the spherical wave reaches to receiver not front part. So it takes longer time. But what do you say about concentrated waves (like LASER) ? What would be its speed and direction?
Suppose, we have a moving source emitting some matter
If matter emitted to same direction then its speed will increase.
If matter emitted in reverse direction then its speed will decreases.
If matter emitted in perpendicular direction then its speed increases and direction changed.
So, no matter what source's motion can affect speed of matter and in some case direction.
But what I am thinking is if source emits wave then source motion cannot affect speed and direction.
But you are saying if source's motion can affect wave's direction but cannot speed.
mananvpanchal said:
@harrylin
But you saying that fiber pushes wave to change its direction, if source can push the wave to change its direction then it obviously can change its speed. Because changing the direction is the property of speed of source, and the property definitely can affect the speed of wave if wave is in same direction of source. [..]
You refer to a source that goes faster than the wave; no such thing is possible with light. And it is "obvious" (assumed, reasoned and not disproved by experiments) to people who work in the field that a moving source cannot affect the speed of a wave that propagates away from it at a distance. A sound wave is the propagation of vibration of gas molecules; and at least at a distance, those molecules are not in any way affected by the motion of the air plane.
[..] But as we know source speed cannot affect speed of wave, so source cannot affect wave's direction too. [..]
I'm sorry, repeating an erroneous line of reasoning that you already know to be wrong is counterproductive. Look again at my drawing: the velocity to the right is imposed by the glass fibre, however the velocity "up" is not imposed by the glass fibre. The source can only influence the direction of a wave, not its speed.
Here's another way to look at it: you can direct a wave in any direction that you want. Then, after you have released the wave, it propagates independently from you; the speed of a wave is independent of that of the source as it instead depends on the medium that propagates it. For sound, that medium is the air; for light we can only infer that there is something which we just call "space". Many people think that there is nothing, but that makes it hard to explain the existence of the properties of space which general relativity describes. Therefore Einstein explained it this way.
Here's another way to look at it: you can direct a wave in any direction that you want. Then, after you have released the wave, it propagates independently from you; the speed of a wave depends on the medium that propagates it. For sound, that medium is the air; for light we can only infer that there is something which we just call "space". Many people think that there is nothing, but that makes it hard to explain the existence of the properties of space which general relativity describes. Thus Einstein preferred to explain it this way.
If source cannot affect speed of wave then how it can affect direction of propagation of wave?
Forget about light just now because its velocity is constant.
UP speed is not imposed by source, but RIGHT speed is imposed by source.
Do you agree that resulting speed is = (up + right)? (In case of wave except light)
Again I am clearing my point "I am not telling that moving source can affect speed of wave. I am telling that moving source can neither affect speed nor direction."
You can shine a torch in any direction; and you can also point a loudspeaker in any direction. However, the way you orient your torch or your loudspeaker has no effect on the speed of propagation - there is no reason to think so. :wink:
For a wave the resulting speed can only be c - for all waves, thus including light waves. As you know c, you can easily determine with vector analysis what the resulting upward velocity will be.
Your point - which should have been a question - is erroneous as it is in conflict with both experiment and theory. This forum is meant to explain this "mainstream"model of light propagation; it's useless and even against the forum rules to try to push other theories that are in conflict with the experimental evidence. Sorry.
Ok, that is my lake of knowledge that I don't know what is the experimental evidence that tell me that when I propagate wave to the north and the source is moving to east then the wave propagates to the north-east. Please, let me know about the experiment.
One moving light clock with LASER. Please, explain me why there is diagonal path of the laser beam?
And you also understand that it goes diagonally, correct?
Here I appeal to the principle of relativity.
Suppose you have a spherical source and aperture like described above and you have a laser, both at rest. You align them next to each other and mark their light beam's positions on some screen, also at rest.
Now, in a frame where the sources and screen are moving, the principle of relativity requires that the beams mark the same spots as previously. Since we know that the aperture-based beam goes diagonally and marks its same spot, then we also know that the laser must go diagonally to mark its same spot.
But you have already agreed that it can for an emitter based on a spherical source enclosed with an aperture.
Experiments with lasers have been done in an effort to measure a deviation from "straight out" relative to the laser, but no significant result was found.
It's exactly as with the glass fibre: a laser is made of mirrors, and the mirrors direct the light to be emitted parallel to the laser cavity, perpendicular to its mirrors. So, it's again the same drawing as in post #6. The light cannot (and wont!) bend in another direction when leaving the cavity. :-p
Here is the resultant trajectory again (mostly inside the laser, but continuing outside it):
...i
...i
...i
..i
.i
Dwelling on what others have told you, this development may also help:
- At atomic level, light is emitted omnidirectionally.
- But that happens inside an instrument, which has walls, where the photons reflect, and an aperture, which let's them out.
- The smaller the aperture, the more difficult it will be for the photons to go out unless they come perpendicularly to the aperture.
- The instrument is just a reproduction at small scale of the path that a photon must follow in the outside world if it wants to hit its target, the top mirror of the light clock. Hence if a photon succeeds in going out, it is because it already possesses that trajectory, which in the frame of the instrument we paint as vertical and other frames paint as diagonal.
- You can visualize it as a camera with a pinhole.
- The laser is not substantially different. It also has a cavity and a "hole" (a half-reflecting mirror). It just happens that its mechanics strongly favor the emission of photons in the "right direction". But it does not eliminate a certain degree of divergence, even if unnoticeable.
An interesting question is then: what about massive objects, like a cannon ball? We see it at rest with us. Unlike light, it does share the motion of the source. And then we assume that, when accelerated, it will acquire the additional state of motion that we have chosen, in a certain direction, without further requirement. But there is further requirement. I have no time now to comment upon this, though. Maybe someone would like to.
Hello Friends,
Ok, just give me the last answer and I will be very thankful to you.
Please, look at the image:
The C is traveling path of the source. The A and B is receiver.
The X is a point at which the source fires a laser beam just for a moment.
The source speed is considerable to the light speed.
And, just answer which receiver receives the beam? A or B? I will be satisfied with the answer.
Thanks to all
mananvpanchal said:
Hello Friends,
Thanks to all
We already gave you the answer: the light that will come out of the laser is propagating towards B inside the laser, as follows:
...i t=3
...i t=2
..i t=1
.i t=0
The light will continue in the same direction after it exits the laser.
You left a lot of important things unspecified, but assuming that the important unspecified things are in line with the previous discussion, then B.
Btw, did you understand my reasoning from the principle of relativity?
Thanks harrylin.
Ok, principle of relativity says that laser must go to B.
Suppose, in post 13 there is a concentrated sound source, and speed of source is considerable to sound speed.
What do classical physics say and what do principle of relativity say?
mananvpanchal said:
[..] Ok, principle of relativity says that laser must go to B.
The relativity principle doesn't apply in that way, as motion relative to air also plays a role in the laws of physics. And what will be predicted depends on some lacking details - in particular, if the air is moving along with the source or not, and in what way the sound is directed, if at all (note that that last remark is also valid for light). In practice it's very difficult to create a moving sound source without also creating a flow of air.
However, if you apply Dalespam's instructions of post #11 to a moving source with air in rest, I expect you to find qualitatively the same result as with light as I demonstrated to you before.
Ok, so conclusion is if air and receivers doesn't moves along with source then A receives sound, and if air moving along with source and receivers is steady then B receives sound.
And for light if medium moves along with source or not it always reaches to B!?
mananvpanchal said:
Ok, so conclusion is if air and receivers doesn't moves along with source then A receives sound, and if air moving along with source and receivers is steady then B receives sound. [..]
I found the contrary in my post: in the mentioned analysis if air and receivers don't move along with the source then B receives the sound because the sound coming through the aperture is directed at B. Thus I don't understand how you can conclude the opposite from your construction. Please show it here, so we can understand how you reached your conclusion.
Sound is not directed to B, it is directed to A. The sound wave is perpendicular to traveling path of source.
And if air and receiver don't move along with source then also the wave reaches to B then there should not be any sound cone with supersonic planes.
mananvpanchal said:
Sound is not directed to B, it is directed to A. The sound wave is perpendicular to traveling path of source. [..]
Your wave that moves straight up in stationary air cannot reach Dalespam's aperture which starts straight above it but is moving to the right...
Here's my final attempt to clarify (sorry), sketching the aperture's x-position as function of the time:
...__ __ t=3
..__ __ t=2
.__ __ t=1
__ __ t=0
