Speed of Light: Doubts and Confusions
The discussion revolves around the speed of light, particularly its constancy regardless of the observer's motion and its implications in the context of special and general relativity. Participants express confusion about how the speed of light is measured in different scenarios and the relationship between time dilation and the speed of light.
  • Some participants express confusion about measuring the speed of light when moving towards or away from a light source, questioning how this relates to their observations.
  • There is a mention of the constancy of the speed of light being supported by extensive experimental data related to special and general relativity.
  • One participant asks if the time dilation observed in satellites compared to Earth clocks serves as proof of the constancy of light speed, indicating a lack of clarity on this point.
  • Another participant discusses the relationship between the speed of light and the measurement of time and distance, suggesting that these measurements differ based on the observer's state of motion.
  • There is a reference to the twin paradox and its contentious nature, with differing opinions on whether it is a source of confusion or a straightforward outcome of relativity.
  • Some participants propose that light behaves differently from other objects in the universe, leading to misunderstandings about its properties.
  • A scenario is presented where the distance to Alpha Centauri appears to change based on the observer's speed, raising questions about the implications for measuring light speed.
Participants generally express confusion and uncertainty about the implications of the speed of light and its measurement, indicating that multiple competing views remain without a clear consensus.
Participants highlight limitations in their understanding of the relationship between motion, time dilation, and the speed of light, as well as the complexities involved in reconciling different observational perspectives.
Ricardgomes
Hi all
One things that puzzles me is the speed of light. We measure it always the same speed independently if we are moving or still. But here is where i get really confused: if we are moving against a light ray (imagine that I will "bump" with the light ray), the speed that we measure is the same if we are moving in an oposite direction (light moves one direction while I move the oposite direction but moving away)?
Second doubt: Is the slowing of satelites clocks in relation to the Earth clocks the proof (or at least on of the proofs) of the constant of the light speed? I don´t get it. Its to confusing to me.
Thank you
There is a huge, huge amount of experimental data supporting special and general relativity (which in this context can be used interchangably with the constancy of the speed of light). I could list some of them, but the FAQ in the Relativity Forum has this link, which details them all: http://www.edu-observatory.org/physics-faq/Relativity/SR/experiments.html
I would start there.
Thank you
I will read it very attentively
Is there a special name for the suposed paradox that I proposed in this post: convergence vs divergence between observer moving and light moving (like two cars that are about to cross each other vs two cars that are moving away in the same straight line road)? Is this doubt pertinent? Am I being clear?
Im asking in order to get the answer to this question faster.
Thank you
Could you be more specific, I don't really understand your question.
Thank you
If two cars are moving away from you, one East with speed u, the other West with speed v, then each driver will observe the other moving with relative speed
[tex]\frac{u+ v}{1+ \frac{uv}{c^2}}[/tex]
Since the speeds of cars is very small compared to c, [itex]uv/c^2[/itex] is essentially 0 and so the speed is indistinguishable from u+ v. But it, instead of two cars, we are dealing with light beams going in opposite directions [itex]uv/c^2= (c)(c)/c^2= 1[/itex] so [itex]1+ uv/c^2= 2[/itex] and the speed of each is [itex](c+ c)/2= c[/itex].
Try this overview:
http://www.sparknotes.com/physics/specialrelativity/kinematics/section2.rhtml
The general method for deriving special relativistic effects (as in the link above) is to assume that the speed of light is constant (which experiments have proven over and over again), and everything else comes into place. The key to understanding the, seeming paradoxical, results is that the speed of light is intrinsically connected to how we measure/observe both the passage of time, and the length of physical objects.
Lets say you are (at rest) watching someone traveling at a large velocity in the same direction as a light-beam. You can measure the difference in velocities between the person and the light-beam, and the person can also try to measure the velocity of the light-beam relative to themselves. At low speeds (and using classical, Newtonian physics) your results will would agree, but in special relativity (and in actuality) your results disagree. You can make sense of this, because the way the moving person measures time and distance are different from yours.
Thank you
There is one catch in the GPS time dilatation. The GPS clocks apply 38.6μs of time correction in the satellites clocks per day because of GR and SR time dilatation. The catch is that the correction is constant for all satellites, which move in different directions relative to Earth rotation.
But the 1971 Hafele & Keating plane experiment showed that the amount of time change depends greatly on the direction of movement relative to Earth rotation.
Secondly the GPS position accuracy depends mostly on clock synchronization between the satellites, not on synchronization between the Earth time and satellite time. Most GPS receivers don't have built-in atomic clocks and achieve accuracy of few meters. They relay on time stamp information sent from the satellites.
But the two way constancy of the speed of light is a proved thing (see Michelson-Morley experiment). The SR uses this fact, but beyond that the SR predicts some effects (like the twins paradox) that are contentious and cause many heated discussions.
zhermes said:
The key to understanding the, seeming paradoxical, results is that the speed of light is intrinsically connected to how we measure/observe both the passage of time, and [the] length of physical objects.
I don't know about being the "key" to understanding the "paradox" but it is one of the best explinations for layman like me regarding the invariance of c.
Tantalos said:
... but beyond that the SR predicts some effects (like the twins paradox) that are contentious and cause many heated discussions.
The twin paradox may cause some heated discussion by folks who do not yet understand it but it is not contentious at all once you understand it and certainly causes no consternation for physicists since it is a simple outcome of SR (or maybe it's GR ... I can never remember)
The problem always seems to be believing that light is somehow like anything else in the universe when according to relativity it doesn't work the same as the rest of reality in most any way...
Does it help if you consider the observer as always being in the present and moving at light speed and yet the observation or measurement as always being in the observers past
The way I understand it - The speed of light does not change because the distances change, as you approach speed of light, as an effect of your clock rate changing.
Imagine this scenario. Aplha Centauri is ~4 ly away from you when you are standing still. It may become only 1 ly away if you start traveling at some small fraction of the speed of light (Edit:) towards it. The space contracts in front of you, and it affects the measurement of light speed.
If this was not the case, you could instantly speed up to near speed of light, shoot a bullet near speed of light that would reach to Alpha Centauri in less that 4 years. That is of course not not the case. You see alpha centaury come closer to you as you accelerate and you normally shoot the bullet at it, but an observer sees you shoot a bullet in slow motion and the bullet still reaches the star in more than 4 years.
  • · Replies 26 ·
  • · Replies 34 ·
  • · Replies 93 ·
  • · Replies 25 ·
  • · Replies 42 ·
  • · Replies 51 ·
  • · Replies 53 ·
