Why is the Speed of Light what it is
The speed of light is approximately 186,000 miles per second due to the principles of Einstein's special relativity, which asserts that this is the only speed observed consistently by all inertial observers. Light cannot travel faster or slower because it is composed of massless particles, photons, which must always move at this constant speed. Historical experiments in the 1700s and 1800s identified fundamental constants of nature, leading to Maxwell's theory that predicted electromagnetic waves, including light, would travel at this same speed. The underlying reason for the specific values of the electric and magnetic constants remains unanswered. Ultimately, the speed of light is restricted by the curvature of spacetime, which preserves causality in the universe.
roy_e17
Can anyone explain what restricts the speed of light to about 186,000 miles per second? Why can't it travel faster?
Science news on Phys.org
Fun fact: it actually can't travel slower either. Light always goes at the same speed. Einstein's theory of special relativity says that there is one, and only one, special speed in the universe which is "seen" to be the same by all (inertial) observers. And there are several ways of calculating that light must travel at that speed. (To think of it one way, photons are massless particles, and all massless particles have to move at that one special speed at all times. I don't remember the reasoning behind that offhand, but perhaps someone else can elaborate, or I could look up the details.)
For an alternative explanation, consider this: back in the 1700's and 1800's, physicists did experiments with charged particles and magnets and discovered two fundamental constants of nature, the electric constant \epsilon_0 and the magnetic constant \mu_0. And shortly afterwards, James Maxwell developed a theory that neatly explained the results of those experiments and also predicted that electromagnetic waves should travel at a particular speed, namely 1/\sqrt{\epsilon_0 \mu_0}. If you plug in the numerical values, you get the speed of light. (In fact, at the time, nobody knew that light was an electromagnetic wave, so you can imagine that Maxwell was rather surprised when he calculated the wave speed and found that it matched the speed of light, which had previously been measured.) So you could say that light travels at the speed it does because of the "electrical" and "magnetic" properties of empty space.
Of course, that begs the question of why the electric and magnetic constants have the values they do. We don't really have a good answer for that.
because the “t”>=0
It is to do with the curvature of the spacetime predicted by Einstein, which curves like hyperbolic space (in order to protect causality). If you draw a diagram of hyperbolic space with one time dimension and one space dimension:
Then no single event should be allowed to cross the "space" axis, this means restricting the speed of light to 186,000mi/s (which equates to a 45 deg line going between two hyperbolics), otherwise the information the light carried would cross the "space" axis and reach an observer before an event happened.
(an event can be veiwed as happening anywhere along a hyperbolic line depending on the observers location and velocity, but it cannot jump from one line to the next.)
I got it!Thank you so much!
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
After my surgery this year, gas remained in my eye for a while. The light air bubbles appeared to sink to the bottom, and I realized that the brain was processing the information to invert the up/down/left/right image transferred to the retina. I have a question about optics and ophthalmology. Does the inversion of the image transferred to the retina depend on the position of the intraocular focal point of the lens of the eye? For example, in people with farsightedness, the focal point is...
