How does density affect the speed of sound?
The speed of sound is influenced by the elasticity and density of the medium, with greater elasticity leading to faster sound propagation. While increased density generally slows down sound due to higher mass per unit volume, elasticity plays a crucial role, especially in solids and liquids, where their higher elasticity can outweigh density effects. In gases, sound speed is directly proportional to temperature and inversely proportional to molar mass and density. Increasing temperature at constant volume raises sound speed without affecting density, while increasing pressure by adding gas molecules or decreasing volume raises density, potentially slowing sound speed. Overall, the relationship between density and sound speed is complex, with elasticity often being the dominant factor.
Hereformore
So the speed of sound is dependent upon two properties:
1) Elasticity of the Medium
2) Density of the Medium.
Greater elasticity results in a greater restoring force once the molecules are displaced (similar to a spring) so they return to their original positions sooner meaning they can participate in another compression sooner as well, thus increasing the speed of propagation.
Greater density decreases the speed of sound. The metaphor I'v been using is that, the greater the density the greater the mass per unit volume, so like a spring with a greater mass attached, it will restore/return to its original position more slowly than a material with a lower density.
So we know that:
Vsolids > Vliquids > Gas.
The comparitive densities of the 3 are as follows:
pSolid > pLiquids > pGas
However solids are more elastic than liquids which are thus more elastic than gas.
So in this case, the elasticity trumps the density. (right? Becuase otherwise it just doens't make sense).
For gases, we have the unique case where the speed is directly proportional to temperature and inversely proportional to Molar Mass and Density.My question is, how does density decrease the speed of sound? (is it as i stated above?)
And in gases, what happens when you increase the temperature at constant volume? Or increase the pressure at constant volume?
Increaseing pressure via increased temperature would not affect density so however you look at it it looks to increase the speed of sound.
Increasing pressure by adding more gas molecules or decreasing volume would increase density. What would happen here?
And finally, if you increased the temperature of solid or liquid, would the speed still increase? isn't that breaking the intermolecualr bonds that contribute to its elasticity?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
