Use Graph To Investigate Limit
  • Thread starter Thread starter nycmathguy
    Graph Limit
The discussion revolves around investigating the limit of the function f(x) as x approaches 0, specifically using the graph of f(x) = |x|. Participants explore the behavior of the function from both the left and right sides of zero.
  • Participants discuss the limits from both sides of zero, questioning the interpretation of the graph and the resulting limit values. Some express confusion about the relationship between the graph's behavior and the limit, while others clarify that the limit approaches zero.
The conversation is active, with participants providing insights and clarifications regarding the limit as x approaches zero. There is a mix of agreement and questioning, particularly around the interpretation of the graph and the implications for the limit.
Some participants reference the behavior of the graph for large or negative values of x, discussing its relevance to the limit as x approaches zero. There are also mentions of other functions and their limits, indicating a broader exploration of the topic.
nycmathguy
Summary:: Use Graph To Investigate Limit
Use the graph to investigate the limit of f(x)
as x tends to 0.
Let me see.
I got to use the graph to investigate the limit of f(x) as x tends to 0 from the left and right.
Let y = f(x).
The given function can also be expressed as f(x) = | x |.
The limit of (-x) as x-->0 from the left is positive infinity.
The limit of (x) as x-->0 from the right is positive infinity.
The limit of f(x) as x-->0 from the left and right at the same time is positive infinity.
Can I say the limit of f(x) is positive infinity?
Only if you think for some unfathomable reason that zero and positive infinity are the same thing.
You CLEARLY show a graph in which the y value goes to zero as the x value approaches zero. How can you think that this is positive infinity?
+1
I was thinking about the V shape formed by the graph of y = | x |. In quadrants 1 and 2, the graph starts at (0, 0) and shoots upward through quadrants 1 and 2 into eternity. However, thinking about it, as I walk toward zero on the x-axis from the left and right, the graph does reach a height of zero. The limit is 0.
Mark44 said:
+1
What does +1 mean? Please, read my reply to phinds.
+1 means I agree with what phinds wrote.
Since the problem was to find the limit as x approaches zero, it's immaterial what the graph does for large x or for very negative x.
What about if the graph is y = -| x | as x tends to 0? You said: "...it's immaterial what the graph does for large x or for very negative x." Can you provide an example using another function?
By the way, are you the same MarkFL from Florida? He is very popular in other math forums.
Do you have some belief that -0 is different from +0 ?
click on his avatar to see that he is from Washington State
Same limit value.
$$\lim_{x \to 0} |x| = \lim_{x \to 0} -|x| = \lim_{x \to 0} x^2 = \lim_{x \to 0} x^3 = 0$$
If you're investigating the limit of some function as x approaches zero, why would you want to check on what happens if x is very large or very negative? That's what I meant by "it's immaterial".
Mark44 said:
Same limit value.
I get it now thanks to you. This is a great site.
No. Obviously, -0 = +0 = no value. Yes, you are right. He is not MarkFL. I do miss MarkFL. What an incredible mathematician he truly is. Member jonah ruined my friendship with MarkFL. Sorry but I needed to bring this into light.
  • · Replies 20 ·
