Spherical, cylinder and polar coordinates
9 replies · 7K views · last reply
kliker
I can't really understand something in spherical and cylinder coordinates
let me start with polar coordinates first
if we have for example x^2 + y^2 = 4 this is a circle with center (0,0) and radius 2
in polar coordinates x and y will be
x = rcosφ
y = rsinφ
0<=r<=2
0<=φ<=2π
here φ is from 0 to 2π but sometimes i see in problems they take φ to be from -π/2 to π/2
for example in a circle like this where you want to find the area
[PLAIN]http://img576.imageshack.us/img576/333/87706111.jpg
why we have to take here r from -π/2 to π/2? I mean, the definition says from 0 to 2π right?
this is my first question about polar coordinates
let's go to spherical
let's say we have this sphere x^2 + y^2 + z^2 = 1
x = rsinθcosφ
y = rsinθsinφ
z = rsinθ
0<=r<=1
now sometimes i see this kind of definition about θ and φ
-π/2<=θ<=π/2
0<=φ<=2π
or this
-π<=θ<=π
0<=φ<=π
how can i know which one to take in different kind of problems? also i can't understand the difference between the both, aren't they the same thing? and why don't we have θ in polar coordinates?
in cylinder we have the same definitions with polar coordinates except one thing, we have z too
i would appreciate any explanation provided, i can't find anything online, and our teacher didnt explain these stuff at all
thanks in advance
Hi kliker! :smile:
kliker said:
… here φ is from 0 to 2π but sometimes i see in problems they take φ to be from -π/2 to π/2
(you meant φ of course :wink:)
φ always has to go from 0 to 2π (or from -π to π, or any other interval of length 2π).
In this case, however, there are no values for π/2 < φ < 3π/2, so we can leave them out.
-π/2<=θ<=π/2
0<=φ<=2π
or this
-π<=θ<=π
0<=φ<=π
You can use either system, there is no difference.
(I've read somewhere that physicists prefer one system, and mathematicians prefer the other. :rolleyes:)
Use whichever you prefer (in an exam, I can't see how it would matter). :smile:
… and why don't we have θ in polar coordinates?
Polar coordinates usually do use θ, and cylindrical coordinates usually use φ (I expect to avoid confusion).
Hi tiny-time, thanks for the answer I think that I get it right now, but let's look on this example
suppose that we want to calculate I where
Triple integral I equals the integral over region D of z dx dy dz, written as a single line of integral signs with differentials.
where D = {(x,y,z) ER^3: x^2+y^2+z^2<=1}
using spherical coordinates we have
x = rcosθsinφ
y = rsinθcosφ
z = ρcosθ
also
0<=ρ<=1
0<=φ<=2π
-pi/2<=θ<=p/2
now If I try to calculate the following integral
Triple integral in LaTeX-style text: integral from 0 to 1 of rho cos(theta) rho^2 sin(theta) d(phi) d(rho), with limits 0 to pi/2 and -pi/2 to pi/2 for theta, and 0 to 2pi for phi.
I find result 0, but the correct result is π/6
i can't understand what I am doing wrong
also as for the cylinder, you're right it's φ
but what's the difference between φ and θ? I can't really get it, why we use two different letters if they are the same thing?
i found this somewhere
this is for ρ
[PLAIN]http://www.math.montana.edu/frankw/ccp/multiworld/multipleIVP/spherical/rho.gif
this is for φ
[PLAIN]http://www.math.montana.edu/frankw/ccp/multiworld/multipleIVP/spherical/phi.gif
this is for θ
[PLAIN]http://www.math.montana.edu/frankw/ccp/multiworld/multipleIVP/cylindrical/theta.gif
thanks in advance
Your limits for θ are wrong. θ runs from 0 to π.
With spherical coordinates, you have the radial distance and two angles. There are various conventions on how these angles are defined and what they are called, and that's what's messing you up. For the equations you wrote,
[tex]x = r \sin \theta \cos \phi[/tex]
[tex]y = r \sin \theta \sin \phi[/tex]
[tex]z = r \cos \theta[/tex]
θ, the angle measured from the +z-axis, goes from 0 to π, and ϕ, the angle measured from the +x axis to the projection onto the xy-plane, typically runs from 0 to 2π. Sometimes people use the interval [-π,π] for ϕ.
i think i made a mistake in my previous integral
Triple integral of rho cos(theta) rho^2 sin(theta) with respect to phi, theta and rho: the limits are rho from 0 to 1, theta from -pi/2 to pi/2, and phi from 0 to 2pi.
here θ goes from -pi/2 to pi/2, isn't this the same as 0 to π?
and φ from 0 to 2pi
x = rcosθsinφ
y = rsinθcosφ
z = ρcosθ
You have φ and θ interchanged from the way most calculus texts do it. And, even so, your equations don't jibe with the usual notation. They also don't jibe with your animations below. Those animations illustrate θ being the usual polar coordinate angle in the xy plane going from 0 to 2π and φ being the angle between the z axis and the spherical ρ. φ goes from 0 to π in the animations.
this is for ρ
this is for φ
this is for θ
thanks in advance
and φ from 0 to 2pi
No, it's not. You would never be able to describe a point where z<0 if you used that range.
The answer to your original problem should be 0, not π/6. You're essentially calculating the average of the z-coordinate over a sphere, which, by symmetry, you should be able to see will be 0. Are you sure you stated the problem correctly?
im totally confused right now, the book says
φ goes from 0 to 2pi, and θ from -pi/2 to pi/2 then on some other page, it says θ goes from 0 to pi and now from the shapes, φ must be from 0 to pi?
@vela, I checked the problem statement again, you're right, It says z should be >=0
I suspect there's some missing info here that would clear up these apparent contradictions. How is θ defined in your book (for the first case you mention)?
It helps to think about what points on the sphere the various values of θ and ϕ correspond to. They're similar to latitude and longitude for locating a point on the globe. Different values, like θ=π/4, Φ=0 and θ=-π/4, Φ=π can correspond to the same point, namely (1/√2, 0, 1/√2), but usually, you restrict the values of θ and ϕ so that this doesn't happen.
In this case, the integral should evaluate to π/4, not π/6.
yes it's pi/4
θ for the polars is from 0 to 2pi
i have another question
is -pi to +pi the same as 0 to 2pi?
or the same as -pi/2 to pi/2?
in the first shape, if the circle has a center that is not 0,0
in polars we have to use θ where θ goes from 0 to 2pi right? but this works if the center is on 0,0 only, why is that?
