Spherical Geometry (Two dimension ) Defining a metric
11 replies · 3K views
Arman777
Insights Author
I am trying to understand how to define a metric for a positively curved two-dimensional space.I am reading a book and in there it says,
On the surface of a sphere, we can set up a polar coordinate system by picking a pair of antipodal points to be the “north pole” and “south pole” and by picking a geodesic from the north to south pole to be the “prime meridian”. If ##r## is the distance from the north pole, and ##θ## is the azimuthal angle measured relative to the prime meridian, then the distance ds between a point ##(r,θ)## and another nearby point ##(r+dr,θ+dθ)## is given by the relation
$$ds^2 = dr^2 + R^2sin^2(\frac {r}{R})dθ^2$$
where ##R## is the readius of the sphere.
If I think ,flat two dimensional space the metric will be;
$$ds^2 = dr^2 + r^2dθ^2$$
I know the derivation of this so it gives me a bit clue about it,
In this case
So in positively curved space instead of ##rdθ## we will have ##R^2sin^2(\frac {r}{R})dθ## which its kind of obvious.
So anyone who can help to understand the concept maybe an image ?
Orodruin said:
I am not sure I understand what your question is.
I didnt understand where the $$ds^2 = dr^2 + R^2sin^2(\frac {r}{R})dθ^2$$ comes from. Like It writes there yes but I can't make a picture in my head...In example why there is sin function ?
So I guess I find it, here ##k=Rsin(\frac {r}{R})## cause when we set ##r=R## we should get a ##k=R##.
So $$ds^2 = dr^2 + R^2sin^2(\frac {r}{R})dθ^2$$
In here its actually ##ds^2 = dr^2 + k^2dθ^2## ?
When you set ##r = R## you have an angle from the pole that corresponds to one radian and so you get ##R \sin(1~\mbox{rad})## as your ##k##. Note that the ##r## you have marked in the figure is not the ##r## coordinate or the radius of the circle along the sphere's surface. The ##r## coordinate is the distance from the pole along the surface of the sphere.
I need an image I guess..I am unfamilier with polar coordinates.Its hars for me to describe and understand in those terms.
Orodruin said:
Consider a circle on the sphere around one of the poles of radius ##r##. What would be the circumference of this circle?
##sin(r)## ? where ##0≤0≤π## ?
Polar coordinates on the sphere work just as polar coordinates in a plane. You refer to a point by using the distance ##r## and direction ##\theta## from the origin.
I guess I understand, For a case where unit circle ##ds^2=dr^2+sin^2(r)dθ^2## this is true. If we take a part of a circle in this sphere then the radius of the sphere will be ##sin(r)##. But since its not a unit circle, the radius of a given circle in the sphere will be, ##Rsin(\frac {r} {R})## so then It turns just a normal circle metric.
