Spherical raindrop, mass, radius, and time
The discussion revolves around a problem involving the relationship between the mass and radius of a spherical raindrop, as well as the rate of change of mass over time. Participants are tasked with finding an expression for the radius as a function of time, r(t), given an initial radius at t=0.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the integration of variables and the challenges of expressing mass in terms of radius. There are questions about the appropriate use of the mass equation and the differentiation process. Some participants express uncertainty about the integration steps and the application of the chain rule.
Several participants are actively engaging with the problem, seeking clarification on the integration process and the relationships between the variables. Guidance has been offered regarding the use of the mass equation and the need to differentiate with respect to time, indicating a productive direction in the discussion.
Participants note the lack of a clear function for radius as a function of time, which complicates the integration process. There is also mention of the initial condition provided for the radius at t=0.
Raquel Aduriz
Separate variables and integrate to find an expression for r(t), given r0 at t=0
M=ρ(4/3)πr3, thus V=(4/3)πr3
dM/dt=Cr3 where C is a constant
∫dM=∫Cr3dt
M+constant=??
I have no idea how to integrate r because it's a function of t but we're not given the function. I don't think that integrating the left side this way will be very helpful either. Any advice would be much appreciated!
∫dM=∫Cr3dt
M+constant=??
You want to express M in terms of r. Once you do that, then dM(r) / dt = Cr3, and you can separate the variables to get r on one side and dt on the other.
Ok... I guess I don't really understand how to do that. Can I do that using just the M equation, or do I need something else?
You gave an expression for the mass of the raindrop in terms of the radius right there in Section 2 of the template. It's the equation M = ...
Alright, so I have M=ρ(4/3)πr3. What exactly do I do with this? Take the derivative and set it equal to the other? Sorry, I'm sure I'm missing something really obvious.
This problem is about solving a differential equation by separation of variables. Have you studied how to do this yet?
Yes, but a few years ago so maybe I've forgotten something key. So I have C*r*dt=ρ*4*π*dr. Is that correct?
Not quite.
Presumably, as the rain drop falls, it gets bigger as it collects more moisture; therefore, the radius of the drop grows as time passes.
Since the drop is spherical, M(t) = ρ(4/3)π*[r(t)]3, where M and r are written as functions of time.
You are also given the condition that the change in the mass of the drop, dM(t)/dt, at any given time is proportional to the cube of the radius of the drop, or dM(t)/dt = Cr3. At t = 0, r(t) = r(0) = r0.
You should check your differentiation of M(t) w.r.t. time. You might have to use the chain rule here, since M is a function of r, but r is a function of t.
I got it! Can't believe I forgot about the chain rule. Thank you so much for your help!
  • · Replies 30 ·
