Why Is My Calculation of dS/dt for a Shrinking Spherical Raindrop Incorrect?
  • Thread starter Thread starter Jay Chang
    Spherical
The discussion centers on deriving the correct differential equation for the surface area of a shrinking spherical raindrop, which evaporates at a rate proportional to its surface area. The user has successfully calculated dV/dt and dr/dt but struggles with dS/dt, realizing that the equation must not include independent variables like volume. They initially derived dS/dt as -8kπr but need to express r in terms of volume to meet the problem's requirements. The user attempts to substitute r using the volume formula but remains uncertain about the correctness of their approach. The conversation emphasizes the importance of adhering to the problem's constraints while utilizing mathematical tools like LaTeX for clarity.
Jay Chang
A spherical raindrop evaporates at a rate proportional to its surface area with (positive) constant of proportionality k; i.e. the rate of change of the volume exactly equals −k times the surface area. Write differential equations for each of the quantities below as a function of time. For each case the right hand side should be a function of the dependent variable and the constant k. For example, the answer to the first question should not depend on S or r.
I was able to find dV/dt, dr/dt using mathematical models but I can't figure out why my answer isn't right for dS(surface area)/dt.
My dV/dt is -k\left(36\pi \right)^{\left(\frac{1}{3}\right)}V^{\left(\frac{2}{3}\right)}
My dr/dt is -k.
Because the equation for the surface area is 4*pi*r^2, the derivative of this would be 8*pi*r dr/dt.
Thus, this can be rewritten as -8k*pi*r. However, because my right side cannot include any independent variables, I must write by r in terms of Volume, which is r = (3V/4pi)^(1/3). So I put down my answer using these but in turns out its wrong so I'm kinda lost.
Here's my second attempt. My s is s = ((36pi)^(1/3))*V^(2/3). Taking the derivative of this would be {(2((36pi)^(1/3))*V^(-1/3))/3}*(dv/dt). And I think plugging in dv/dt would give me a solution but if that's the case, I don't know why my answer would differ.
Also, if there's any way to put down formulas without using brackets and stuff, would much appreciate it if someone can tell me
According to the problem statement, the DE for the surface area should not contain the volume. Also, you can use LaTeX through mathjax. See the latex part of the about page.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 33 ·
