Spin Orbit Coupling + Magnetic Field
5 replies · 2K views · last reply
t0pquark
For the ground state of a certain atom, the spin-orbit interaction and magnetic field interaction give the Hamiltonian ##H = E (J^2-L^2-S^2) + \frac{\hbar e B}{2mc}##.
Find the four matrix elements ##\langle J, J_z \vert H \vert J', J_z \rangle ## for the states ##\vert J = \frac{3}{2}, J_z = \frac{1}{2} \rangle ## and ##\vert J = \frac{5}{2}, J_z = \frac{1}{2} \rangle ## (and their four possible combinations).
"Your answer should make use of a table of Clebsch-Gordon coefficients and require minimal math."
I am pretty confused where to even start with this question, which is not a good thing less than a week before the final :(. One thing in particular that I don't get is that I thought we were using the Clebsch-Gordon coefficients for ##\vert jm \rangle ## states, not for ##\vert J, J_z \rangle ##.
Where should I start?
Are you sure the Hamiltonian is correct? I would expect some operator in the term for the magnetic field.
The Hamiltonian includes the operators ##L^2## and ##S^2##, so you will need to express the ##| J, J_z \rangle## states in terms of eigenstates of ##L^2## and ##S^2##. This is where the CG coefficients will come in.
Oooops that was definitely me copying incorrectly. The Hamiltonian should be ## H = E (J^2-L^2-S^2) + \frac{\hbar e B}{2mc}(L_z+2S_z)##
Okay so starting with the Clebsch-Gordon table I want to use the section with 2 x 1/2??
I think I would get ## \vert J = \frac{5}{2}, J_z=\frac{1}{2} \rangle = \sqrt{\frac{2}{5}} \vert 1, -1/2 \rangle + \sqrt{\frac{3}{5}} \vert 0, +1/2 \rangle ## and ## \vert J = \frac{3}{2}, J_z=\frac{1}{2} \rangle = \sqrt{\frac{3}{5}} \vert 1, -1/2 \rangle - \sqrt{\frac{2}{5}} \vert 0, +1/2 \rangle ##
Do I then apply each term of the Hamiltonian to this? I'm still kind of fumbling around for what to do here.
I don't think this is correct. Just to be clear: what is the notation here?
You are on the right track. When you have transformed the ##| J, J_z \rangle## into kets that are simultaneous eigenkets of all the operators in the Hamiltonian, you apply ##H## to those eigenkets and then take the inner product with the bra.
I think this is where I'm confused. My logic was that the total angular momentum must be 2 and the total spin angular momentum must be 1/2, so I would want the 2 x 1/2 section on the Clebsch-Gordan table, then I find the results for ## \vert J = \frac{5}{2}, J_z = \frac{1}{2} ## and ## \vert J = \frac{3}{2}, J_z = \frac{1}{2} ## by reading down. I guess I don't really understand what I'm doing here.
I can apply each term of the Hamiltonian if I know ## j, l, s ## (like ## L_z \vert l, m \rangle = \hbar m \vert l, m \rangle##), but I'm not sure what I get out of the Clebsch-Gordan table.
You are correct that you must have ##L=2##, ##S=1/2##.
You want to go from ##|J,J_z \rangle## to ##|L, M_L, S, M_S\rangle##, so you have
|J,J_z \rangle = \sum_{L,M_L,S,M_S} |L, M_L, S, M_S\rangle \langle L, M_L, S, M_S |J,J_z \rangle
where the ##\langle L, M_L, S, M_S |J,J_z \rangle## are the CG coefficients.
Once you have these decompositions, you can know the action of each of the angular momentum operators on the kets ##|J,J_z \rangle## and you can build the matrix for the Hamiltonian.
