Spinning Superconductor Questions
This discussion centers on the properties and capabilities of spinning superconductors, specifically their ability to lift materials and the conditions required for their operation. Key points include the 'London moment', a phenomenon where a spinning superconductor generates a magnetic field aligned with its spin axis. The relationship between energy input and the force exerted (in Newtons) is questioned, alongside the necessity of cooling for superconductors to function effectively. The discussion also touches on the specifics of mass and charge in relation to superconducting materials.
  • Understanding of superconductivity and the London moment
  • Familiarity with quantum mechanics, particularly in relation to electron behavior
  • Knowledge of magnetic fields and their interaction with superconductors
  • Basic principles of force and energy in physics
  • Research the principles of superconductivity and its applications in technology
  • Explore the mathematical formulation of the London moment in detail
  • Investigate the cooling methods required for superconductors to achieve their properties
  • Study the interaction between superconductors and magnetic materials
Physicists, materials scientists, and engineers interested in advanced materials and their applications in magnetic levitation and energy systems.
jaketodd
If someone(s) would be so kind, I have some complicated curiosities about spinning superconductors. This is not homework.
What types of materials can a spinning superconductor lift?
Does it only work against gravity, or can it work in any direction?
Does it have to be cooled?
How much energy per second would a superconductor need in order to spin in such as way as to continuously exert one Newton on something very near to it? Is this relationship linear (between energy and Newtons)? Also, is the relationship between acceleration due to Newtons applied, and the mass the Newtons are applied to, linear?
Thanks,
Jake
are you talking about this?
http://en.wikipedia.org/wiki/London_moment
The 'London moment' is a quantum-mechanical phenomenon whereby a spinning superconductor generates a magnetic field whose axis lines up exactly with the spin axis
The magnetic field strength associated with a rotating superconductor is given by:
where M stands for the mass of the mass, and Q for the charge of the superconducting carriers. For the case of Cooper pairs of electrons, M=2me and Q=2e. Despite the electrons existing in a strongly-interacting environment, me denotes here the mass of the bare electrons [6] (as in vacuum), and not e.g. the effective mass of conducting electrons of the normal phase.
Does M = 2me for an arbitrary mass? Is M for the spinning superconductor or the thing it is supporting? Does Q = 2e for an arbitrary mass (arbitrary number of electrons)? Is Q for the spinning superconductor or the thing it is supporting? And I assume w is rotational frequency of the superconductor? Does it need to be cooled? And I assume it can only lift magnetic objects?
Thanks!
Jake
it should be 2me
e stands for 'electron'
  • · Replies 18 ·
  • · Replies 77 ·
  • · Replies 30 ·
  • · Replies 138 ·
