Spring and Gravity Potential Energies
brendan3eb
A 2-kg block is dropped from a height of 0.4 m onto a spring force whose constant k is 1960 N/m. Find the maximum distance the spring will be compressed.
U1+K1=U2+K2
both the initial and final kinetic energy should be 0 so we should get an equation like this:
mgh=(1/2)kx^2+mg(value)
I can't find an expression to put in for value that only has x and no other unknown variables.
The expression you have will work.
Hint: Let the lowest point the block reaches be h=0m.
so I would substitute 0 in for value to get x = .089 m, correct? Yeah, that's what I have been getting. However, my teacher told me the answer is 1.00 m. I am starting to wonder if he read off the wrong answer. Do you get .089 m too?
I also get .089m. Check to make sure your numbers and units are correct. If they are, then I suggest talking to your teacher about it. Even teachers aren't perfect!:smile:
Technically, the method we are using assumed the spring is compressed a negligible amount, but I think this is a reasonable assumption that wouldn't change the answer that much.
