Spring Constant Force Problem Help
12 replies · 2K views
Thana
If you apply a greater force, will the spring constant remain the same, increase, or decrease?
PEe=1/2kx^2
I'm leaning towards the same, or maybe increase. I actually have no clue.
Thana said:
Homework Statement: If you apply a greater force, will the spring constant remain the same, increase, or decrease?
Relevant Equations: PEe=1/2kx^2
What is your reasoning for that? Say it in your own words.
Reply
When you increase the force the spring compresses more, so the spring Constant increases? Spring Constant is the resistance.
The term constant in spring constant is a clue!
Reply
  • Haha
Resistance to what? What equation comes to mind that involves the spring constant? What is the definition of each term in this equation?
F=-k/x is hooke's law.
force, spring Constant, and displacement. so if we set x=2 and solve for k if force is 2 and 4, the k would be 1 and 2, so it increases?
No, F=-kx
How can the same extension applied to the same spring result in two different forces?
Reply
If spring is linear, then F = kx and k is the same, a constant. Greater force gives greater deflection but k is constant and the same, as long as it is a linear spring.
Actually F=-kx. The negative sign is important because it says that the force F is always opposite to the displacement x, i.e. the force is restoring.
Reply
The value of the spring constant is found experimentally.
For linear springs, it is a constant of proportionality between force on the spring and its deformation.
Please, see:
https://en.wikipedia.org/wiki/Hooke's_law#Formal_definition
How can the force change from 2 to 4 if the value of x stays constant? Are you picturing in your mind the spring?
kuruman said:
Actually F=-kx
Not if by F you mean the magnitude of ##\vec{F}##. The correct expression is ##F_x=-kx##.
"F" in F = - kx is the symbol standing for a one-dimensional vector and can be positive when x < 0 or negative when x > 0. This convention is also the case in other 1-D equations such as
x = x0 + v0 t + ½ a t2
where all the algebraic variables except t represent one-dimensional vectors that can have positive or negative values.
Strictly speaking, you are right. However, it is customary to omit the subscript when vectors are either parallel or antiparallel. In the case of F = - kx, the minus sign locks "antiparallel" in the expression.
