Spring stretch for mass moving in circular path
7 replies · 4K views
Lolagoeslala
A 1.01 kg mass is attached to a spring of force constant 9.5 N/cm and placed on a frictionless surface. By how much will the spring stretch if the mass moves along a circular path of radius 0.485 m at a rate of 2.14 revolutions per second?
What i was thinking was using the following equation:
Fc= Kx - mg
Which would turn into
a=kx-g
(4pi^2(R)(F)^2 +g)/K=x
Fc= Kx - mg
a=kx-g
Is it a horizontal surface the mass moves on?
ehild
ehild
It does not state...
I guess the surfaceis horizontal, the angle of inclination would be stated otherwise. So the only force in the plane of motion is the force of the spring. Gravity cancels with the normal force of the surface.
ehild
ehild
Would u like to show me that using the equation...
Kx=Mg somewhere you also need to include the acceleration i guess
Mg is a vertical force. The object moves horizontally, along a circle. What force is needed to make it move along that circle of radius 0.485 m with 2.14 revolutions per second?
ehild
ehild
m= 1.01 kg
K= 9.5 N/cm = 950 N/m
r= 0.485 m
f= 2.14 Hz
Kx= ma
kx= m x 4pi^2 x r x f^2
950 N/mx = 88.472 N
x= 0.0931 m
Your solution is correct.
ehild
