Springs and Hooke's Law -- Unequal forces applied to the two ends....
The discussion revolves around applying Hooke's Law to a spring subjected to unequal forces, specifically 3N from one end and 5N from the other, while the spring is moving but not stretching. Participants explore how to analyze the tension along the spring by dividing it into segments and considering the forces acting on each segment. It is clarified that even though the spring is accelerating, the tension varies along its length, similar to two masses connected by a string. The conversation emphasizes that the tension at any point is influenced by the forces applied at both ends, leading to a better understanding of how tension is distributed. Ultimately, the participants reach a consensus on the mechanics of tension in relation to acceleration and force distribution.
Utilite
Okay here is my question.
Assume that you are pulling a spring with 3N from one end and 5N from the other one. How can we apply Hooke's Law in this case? And let's assume that the spring isn't stretching anymore just to simplify things, but it is accelerating.
If we divide the spring into eight segments. I feel like the net force on the end of third segment is zero (3N is applied to first segment). If that idea is true then we can apply Hooke's Law to each side.
But I couldn't prove that idea and the springs got me really confused.
What do you mean by that? Is the spring stretching or not?
It isn't stretching but it is moving. Like when you stretch a spring hold it and move it around.
But what keeps the spring stretched?
So, you are talking about a rigid rod with a force of 5 N applied at one end and a force of 3 N applied in the opposite direction at the other end, and you are asking how the tension in the rod varies with position along the rod from one end to the other. Is that correct?
Yes that is kind of what i am asking. And also we know that the rigid rod stretched a bit as some force is applied. Can we calculate the stretching using Hooke's Law?
I don't know doesn't the spring stretch when you pull it with some force on different ends. (We first stretched it by pulling it then it stabilized then it started moving around) Perhaps it doesn't it just accelerates(?). I got really confused with springs.
Yes. But first, let's look at the rod. Let M be the mass of the rod. In terms of M, what is the acceleration of the rod? Are all parts of the rigid rod experiencing the same acceleration?
yes definitely. the rod is accelerating with 2N/M. since it is rigid every part is accelerating with same acceleration but how is that possible if tension changes from one point to another
Well, let's just see. Suppose we divide the rod into 8 parts like you did in your first post. What is the mass of each part? Now, suppose we do a free body diagram on the part immediately adjacent to the 5 N end. The tension of the right end of this segment is 5 N, and call the tension on the left end of this segment T. What is the 2nd law force balance on this segment?
Likes Utilite
A small slice of the rod accelerates due to difference in the tension on the two sides.
So if all the parts are to have same acceleration, the difference need to be the same, and not the tension itself.
What does this tell you about the way the tension varies along the rod?
Edit
Sorry, Chet posted a second before. :)
Likes Utilite
Yes now I get it it is just like two masses connected with a string. I was thinking about the tension on a very little dL as just from one side. But now it is actually from two sides. Then what do we mean as tension on some point?
I don't follow your question. The tension is distributed over the local cross section of the rod, at each location.
I am sorry I couldn't state my question properly but it doesn't matter now. I got what I was looking for you have been very helpful thank you.
