Springs and simple harmonic motion
The discussion centers on calculating the acceleration of a mass oscillating on a spring with a period of 1.45 seconds. The user initially calculated the angular velocity as 4.33 rad/s and the amplitude as 8.80 cm. However, the final acceleration calculation of 142 m/s² was incorrect due to failing to convert the amplitude from centimeters to meters. The correct amplitude should be 0.088 m, which will yield the accurate acceleration value.
  • Understanding of simple harmonic motion principles
  • Knowledge of angular velocity and its calculation
  • Familiarity with the equations of motion for oscillating systems
  • Ability to convert units, specifically from centimeters to meters
  • Review the equations of motion for simple harmonic motion
  • Learn about unit conversions in physics, particularly for oscillatory motion
  • Explore the implications of amplitude on acceleration in harmonic systems
  • Practice problems involving mass-spring systems and their parameters
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators looking for examples of common mistakes in calculations involving simple harmonic motion.
Jm4872
A mass is oscillating on a spring with a period of 1.45 s. At t = 0 the mass has zero speed and is at x = 8.80 cm. What is the magnitude of the acceleration at t = 2.30 s?
x(t)=Acos(wt + phi)
a(t)=-Aw^2cos(wt + phi)
a=w^2x
T=2pi/w
I've tried this a few different ways, first off what I do is convert the period (1.45s) to angular velocity using T=2pi/w, this then gives me the result of 4.33 rad/s. Using this I then substitute values into the equation for position to get,
8.80 = Acos(0)
from this equation I then solve for A and receive 8.80 cm.
Now the information I have is..
w=4.33 rad/s
A=8.80cm
t=2.30s
All of this I put into my equation for acceleration to get..
a(2.30)=-8.80(4.33^2)cos(4.33*2.30)
solving for acceleration the result comes to be 142 m/s^2, however when I input this number it comes out to be wrong? I'm confused as to what it is that I'm doing wrong, please help!
You just forgot to convert the amplitude of the oscillation (which is in cm) to metres before computing your answer.
oh wow haha now I feel dumb!
haha thank you!
  • · Replies 51 ·
