Springs connected to a mass in series?
56 replies · 5K views
flinnbella
Find the frequency of oscillation of mass m suspended by two
springs having constants k1 and k2, in each of the configurations
shown.
x = A sinωt + B cosωt
I found the answer for the springs in parallel, but not for the ones in series. I believe I don't understand how the forces are interacting properly.
Here's a force diagram I drew. Everytime I try to make equations from this though my answer doesn't make sense. The mass m has a gravititoanl force applied to it, and spring 2 applies a restoring force to mass m. On spring 1, the mass m applies a gravitational force, and spring 2 applies a restoring force onto spring 1 towards itself. Spring 1 applies a restoring force towards itself.
I think there's something wrong with this interpretation, but I don't understand what.
If there is one spring and you applied a force ##F## you would expect deflection ##\Delta y##. If you use a second identical spring to apply the force ##F## to the first spring what deflection would you expect?
Delta y?
flinnbella said:
Delta y?
Think about the force applied to the second spring, what force is the second spring applying to the first spring?
It is applying k_2*delta_y to the first spring
While it may be true, I’m think it’s missing the point. ##F## is applied to the second spring. What is force is applied to the first? You can think of this like two ropes if you like. If you apply ##F## to the second rope, what is the tension developed in each rope?
If it was two ropes, the force would be F? If the ropes are in equilibrium then T = F, so the force from rope 2 to rope 1 is F?
Correct. ##F## is applied to both ropes. Now, put the springs back. Each spring is acting under applied load ##F##. Meaning the total deflection the end of the second spring sees relative to the origin is ( assuming identical springs)?
The displacement of spring 1 and of spring 2 by the mass m?
Forget the mass for a minute. We are applying a force ##F## with our hands. What is the total deflection of our hand? ( Remember a force ##F## acting on either particular spring causes deflection ##\Delta y## of that particular spring )
Maybe my line of questions isn’t working. Let’s shift gears. Would you write Newton’s Second law for the mass (as you currently believe it to be) so we can examine it?
Netwon second law is that the product of the mass and acceleration of an object is equal to the sum of all the forces applied to it
On third thought this is going to make it worse I think.
They want you to find the ##k_{eff}## value of a single spring that could effectively replace the system of springs to solve your problem. What did you find was that ##k_{eff}## value for the parallel configuration?
Is there a single spring that can replace the two springs? Isn't there a force between the springs as well, so how can a single spring account for that?
With the parallel setup, the displacement is the same for each spring - thus also the same for an equivalent spring replacing both - but the forces from each spring are added together to be applied to the equivalent spring. So:
$$\Delta y_1 = \Delta y_2 = \Delta y_{eq}$$
$$F_1 + F_2 = F_{eq}$$
And, for each spring:
$$F_n = k_n \Delta y_n$$
From these, you found the value of ##k_{eq}## in terms of ##k_1## and ##k_2##. These are basically 6 equations with 6 unknowns, namely: ##F_1,\ F_2,\ k_{eq},\ \Delta y_1,\ \Delta y_2## and ##\Delta y_{eq}##. (We also know that ##F_{eq} = mg##)
Find now the same equations that relate the displacements and the forces together when the springs are in series. Which variables are the same and which ones are added together?
Newton’s third law. That’s the idea I was trying to convey. The force of spring 2 on spring 1 is a third law partner with the force of spring 1 on spring 2 ( together forming a third law pair).
There is an effective spring constant in ether case. You just have to figure out how to apply the constraints.
Does that mean the restoring force of the spring have to equal the force of the weight? But the equal and opposite reaction for the weight is gravity pulling on it. I don't know what the equal and opposite force for the restoring force of the spring is though.
I solved for the parallel case a while ago, I understand how the displacements are the same, and thus the net force is the same as the sum of all the spring forces; however, I don't see something similar for the ones in series
Yes, you already did part of the job earlier:
This means:
$$F_1 = F_2 = F_{eq}\ (= mg)$$
jack action said:
This means:
$$ ... F_{eq}\ (= mg)$$
Just for clarity. When in static equilibrium
Reply
This means:
Ok. So the restoring force of each spring is equal. Then what? We don't know the displacement of each spring.
But you do know the deflection of each( edit: in terms of the other), because you know the force applied to each and the spring constants.
deltay1 + deltay2 is the total displacement, so deltayeq is the same as their sum
Reply
Now use the relationship in #19 to relate the equivalent spring to either of the other springs.
Ok, so k_1*delta_x = k_2*delta_y = k_eq*(delta_x + delta_y).
Yeah, pick one (for the moment) of the spring forces to relate to the effective spring force.
I don't see why we are trying to find this F_eq.
It is a placeholder. We are trying to find the effective spring.
