Springs connected to a mass in series?
The discussion revolves around understanding the behavior of springs connected in series, particularly focusing on the forces and displacements involved when a mass is suspended from them. Participants are exploring the concepts of force interaction, effective spring constants, and the application of Newton's laws in this context.
  • Participants are attempting to analyze the forces acting on each spring and how they relate to the overall system. Questions about the interpretation of forces, the concept of effective spring constants, and the relationship between displacements in series versus parallel configurations are raised.
The discussion is ongoing, with participants providing insights into the relationships between forces and displacements in the system. Some guidance has been offered regarding the application of Newton's laws and the concept of equilibrium, but there is still uncertainty about how to derive the effective spring constant for the series configuration.
Participants are grappling with the implications of forces acting between the springs and the mass, as well as the need to establish equations that accurately represent the system when springs are in series. There is an acknowledgment of the complexity introduced by the interactions between the springs.
  • #31
erobz said:
It is a placeholder. We are trying to find the effective spring
Ok I get that the total displacement of the mass is delta_x + delta_y, and this can be represented by a single spring instead of two. However, I don't see a relationship between the spring constants.
  • #32
Just continue on with #26. You are so close. We can talk about what it means as you go.
You have that ##A = B = C##, we want to pick ##A## or ##B## to relate to ##C##. Then you will use ##A## to relate to ##B##. In the end you will find the spring with constant ##k_{eq}##, that behaves as though it were identical to the series springs.
  • #33
I got k_1+k_2/(k_1 + k_2) = k_eq. So I have the forces in terms of k1, k2.
  • #34
I think you messed up the algebra or the application of the equations ( I can't tell because you don't shot the steps you took)
  • #35
This is what you did for the springs in parallel:
$$F_1 + F_2 = F_{eq}$$
$$k_1\Delta y_1 + k_2\Delta y_2 = k_{eq}\Delta y_{eq}$$
And because ##\Delta y_1 = \Delta y_2 = \Delta y_{eq}##:
$$k_1 + k_2 = k_{eq}$$
So what are you going to do with ##\Delta y_1 + \Delta y_2 = \Delta y_{eq}## in our case with springs in series?
  • #36
k1*k2/(k1 + k2)
  • #37
flinnbella said:
k1*k2/(k1 + k2)
Good. Now divide by numerator and denominator by ##k_1 \cdot k_2## and you will see the start of a more general form that should look familiar if you've taken circuits.
  • #38
Note how much you can stretch two rubber bands (in parallel) at once.
Now, tie two ends of those bands (in series) and stretch both as one.
At the point that you are applying similar force as before, there will be much more stretching (x of balance) for the second case.
  • #39
Oh this makes some more sense, not 100% understanding but it helps. How did you make the graphic?
  • #40
What is still unclear?
Left graphic:
Balance load equals mg.
Both, the strong and the weak spring, must deflect the same in order to produce a combined reactive force equaling mg.
Reactive individual force of strong spring is greater than the reactive individual force of weak spring, but summation of both is the balance load mg.
Could you try describing the right graphic?
  • #41
flinnbella said:
k1*k2/(k1 + k2)
So, if this is k_eq , what do you get for 1/k_eq ?
To restate that:
If ##\displaystyle \quad k_{eq}=\dfrac{k_1 \cdot k_2}{k_1 + k_2} ## ,
then what is ##\displaystyle \quad \dfrac 1 {k_{eq} } \ ? ##
  • #42
To restate that:
1/keq = (k1 + k2)/(k1*k2)
  • #43
Left graphic:
I don't see why the springs both exert a force of the mass. Spring 2 exerts a force because it's attached, but spring 1 isn't directly connected to the mass so how can it apply a force to the mass? Makes no sense.
  • #44
Yeah, but now you can turn that into something familiar (resistors in parrallel) by dividing each term in the numerator by the denominator.
They don't both exert a force on the mass. The FBD of the mass only includes its weight and the force from sping 2. That force is transmitted through spring 2 and is applied to spring 1. Then that force is transmitted through spring one to the fixed structure.
  • #45
What prevents spring 2 to fall down to the ground, together with the attached mass, is a force of magnitude mg pulling them up.
The net force on that spring 2 is then zero, and it remains in balance.
Exactly the same thing happens to spring 1 (which is attached to ground and to spring2-mass).
  • #46
Simplify that.
(k1 + k2)/(k1*k2) = k1/(k1*k2) + k2/(k1*k2) = ?
  • #47
The mass exerts a force on spring 2 and spring 2 must exert the same force on spring 1.
The fascinating thing is that since both spring displacements are added up such that the total displacement is always larger than any of the springs alone, the equivalent spring that would replace both springs is also always less stiff than the softest of the springs.
  • #48
Why does spring 2 exert same force on spring 1? I don't think those are force action-reaction pairs.
  • #49
The hand pulls on the spring with force ##F##.
What force does the wall apply to the spring? What force does the spring apply to the wall? Remember, we are talking about "massless" springs. Free the spring from external bodies and sum external forces i.e. ##\sum F_{ext}= \cancel{m}^0 a = 0 ##
  • #50
Yes, there are.
Doing the free body diagrams (FBD) for each component (the ceiling ##c##, the spring ##k_1##, the spring ##k_2## and the mass ##m##):
By definition, from one FBD to the next:
$$F_c = F_{k1}$$
$$F_{k1} = F_{k2}$$
$$F_{k2} = F_m$$
mass FBD:
$$F_m = mg$$
Therefore:
$$F_c = F_{k1} =F_{k2} = F_m = mg$$
The force ##mg## goes through every component.
  • #51
jack action said:
Yes, there are.
$$F_c = F_{k1}$$
$$F_{k1} = F_{k2}$$
$$F_{k2} = F_m$$
mass FBD:
$$F_m = mg$$
Therefore:
No, that can't be right. F K1 would be directed upward, not downwards, because the spring will be stretched downwards, and so FK1 will apply a restoring force upwards.
  • #52
On the thing that is attached to below ( i.e. spring 2 ) it is applying a restoring force ##F_{k2}##, which is equal and opposite the force that is applied to spring 1. (##F_{k1} = - F_{k2}##)
  • #53
jack action said:
The force mg goes through every component.
This is true but that means they all have magnitude mg but they are not all mutually action-reaction pairs. There are three such pairs but the others are known equal and opposite because each spring is not experiencing acceleration or deformation.
  • #54
And in the case of the oscillator( which is @flinnbella original problem) the forces on opposite ends of each spring are equal and opposite because the springs are “massless”.
  • #55
Yes I had forgotten the Original Post!
  • #56
Yeah… we have been walking around a little bit in hopes to get a flag in the ground…somewhere.
  • #57
Those are only the magnitudes. You can see the direction of the vectors on the drawing where I already assumed that the forces acting on each component are equal and opposite.
  • · Replies 31 ·
  • · Replies 58 ·
