- 42,895
- 983
Once again, no one said you can[t graph a relation that is not a function. A circle is the graph of a relation that is not a function. It fails the "vertical line test": any vertical line that passes through the graph does so only once.
The graph of (y+4)2= x is a "parabola lying on its side" but y is NOT a function of x. If x= 4, then y can be either -2 or -6: the vertical line x= 4 passes through the graph at both (4,-2) and (4,-6).
However, the function [itex]y= \sqrt{x}[/itex] is defined as "the positive number whose square is x" and is a function. Then [itex]y= \sqrt{x}- 4[/itex] is the part of a parabola that starts at (0,-4) and rises upward and two the right. The functions domain is [itex][0,\infty)[/itex] and its range is [itex][-4,\infty)[/itex].
