Undergrad Square root of the delta function
The discussion centers on the evaluation of the integral involving the square root of the delta function, specifically whether it can be treated as a delta function itself. Participants suggest approximating the delta function with finite spike functions to explore the behavior of the square root, leading to the conclusion that it likely does not exist as a valid distribution. The conversation also touches on Bell's theorem and convolution properties, indicating that if a function exists that satisfies certain conditions, it contradicts previous findings about the square root of the delta function. Ultimately, the consensus leans towards the idea that the square root of the delta function either does not exist or does not behave as one might expect. The complexities of distribution theory and the implications of these findings are also highlighted.
junt
Is square root of delta function a delta function again?
$$\int_{-\infty}^\infty f(x) \sqrt{\delta(x-a)} dx$$
How is this integral evaluated?
You could try approximating the delta function by a sequence of finite spike functions and see what happens.
This is actually related to Bell's theorem. It is not the solution to the OP : searching A s.t. $$\int A (a,\lambda)A (\lambda,b)d\lambda=-cos (a-b) $$
If we make the assumption $$A (a,\lambda)=f (a-\lambda) $$ and let $$u=a-\lambda $$ we get a convolution :
$$\int f (u)f (a-b-u)du=-cos (a-b) $$
Using the Fourier convolution theorem :
$$2F^2 (\omega)=-\delta (\omega+1)-\delta (\omega-1)$$
Hence the searched function f is given by
$$f (x)=\frac {i}{\sqrt {2}}\int e^{ikx}\sqrt {\delta (k+1)+\delta (k-1)} $$
Bell's theorem shows that there is no such f.
Addendum : no such f in the range -1 to 1
junt said:
∫∞−∞f(x)√δ(x−a)dx​
not every sequence of mathematical symbols makes sense
You could aslo think it in the functional sense : ##\int\delta(x-y)f(y)dy=f(x)=:\Delta_x(f)##
Then the root of delta would be a semi evaluation of f , which you could compute by semi integrating, using Cauchy's formula for repeated integration extended to real values of fractional calculus :
##\sqrt{\Delta_x}(f)=\frac{1}{\Gamma(1/2)}\lim_{y\rightarrow\infty}\int^y\delta(x-y)f(t)(y-t)^{-1/2}dt##
Error : my last formula is wrong since it contains a function depending on the limits of integration hence Cauchy's formula for repeated integral cannot be so easily used
I have never met such a formula before. If it can exist, I suppose
\int f(x)\sqrt{\delta(x-a)}dx=\int \frac{f(x)}{\sqrt{\delta(x-a)}}\delta(x-a)dx=\frac{f(a)}{\sqrt{\delta(0)}}=0
Likes Delta2
and then check that what it is happened does not depend on a sequence
EDIT: I just realized that this thread is three years old...
To me it seems like ##\sqrt{\delta(t)}## probably doesn't exist. Here is my thinking (this is not a proof).
First, as suggested by PeroK, start with one particular sequence of finite spikes that converges to a delta function. Let ##p_n(t) = n## for ##-\frac{1}{2n}\leq t\leq\frac{1}{2n}##, and zero everywhere else. If ##\sqrt{\delta(t)}## exists, then I would hope that the sequence ##\sqrt{p_n(t)}## would converge to it. Let ##\phi## be a continuous test function, then
\begin{eqnarray*}
\lim_{n\rightarrow\infty}\int \phi(t) \sqrt{p_n(t)} & = &
\lim_{n\rightarrow\infty} \sqrt{n}\int_{-1/2n}^{1/2n} \phi(t) dt \\
\lim_{n\rightarrow\infty} \sqrt{n}\,\phi(\tau)\int_{-1/2n}^{1/2n} dt
\end{eqnarray*}
for some ##\tau \in [-\frac{1}{2n}, \frac{1}{2n}]##. Then obviously we find that the limit is zero. So we have ##\sqrt{p_n(t)}\rightarrow 0##, even though ##p_n(t)\rightarrow \delta(t)##. This suggests that either ##\sqrt{\delta(t)}=0## or it doesn't exist.
Now I want to look at the product of ##\sqrt{\delta(t)}## with itself. We usually don't talk about multiplying distributions since in general the product of two distributions is not a distribution. However, multiplication of two distributions is allowed in those cases where the product is a distribution. In this case, if ##\sqrt{\delta(t)}## is a distribution then obviously it can be multiplied by itself to give the delta distribution. Also, if ##\sqrt{\delta(t)}## is a distribution then it has a Fourier transform that we will denote by ##\mathcal{F}\left[\sqrt{\delta(t)}\right]=F(\omega)##. Now we can use the convolution theorem for Fourier transforms $$
\begin{eqnarray*}
1 & = & \mathcal{F}\left[{ \delta(t)}\right] \
& = & \mathcal{F}\left[\sqrt{ \delta(t)}\sqrt{ \delta(t)}\right] \
& = & \frac{1}{2\pi}F(\omega)\ast F(\omega).
\end{eqnarray*}
I don't know whether a distribution ##F(\omega)## exists that is a constant when convolved with itself. If ##F(\omega)## doesn't exist, then neither does ##\sqrt{\delta(t)}##; if it does exist then clearly ##F(\omega)\neq 0##. However, this seems to contradict our earlier finding that suggests ##\sqrt{\delta(t)}=0## which would imply ##F(\omega)=0##.
So I suspect that ##\sqrt{\delta(t)}## doesn't exist. Or if it does exist, it doesn't mean what the notation suggests it should mean.
jason
Likes wrobel
$$\delta(x)$$ is not a function but a distribution according to Distribution Theory, I do not think of any possible case of finding it under a squareroot?
About multiplication of generalized functions see Colombeau theory of generalized functions
Likes jasonRF
Do you know of any references on Colombeau theory that are appropriate for non-mathematicians? It looks intriguing, but the references that popped up with a quick google search seem to require a little more mathematical knowledge/sophistication than I have. There are many "simple" treatments of the Schwartz theory of distributions - such as the book by Strichartz (where I first learned it). Is there anything equivalent for the Colombeau theory, or does it inherently require more tools to properly explain?
thanks,
Jason
Supplement to post #9
As eigenfunction of x, ##\delta(x)## have the relation
f(x) \delta(x) = f(0) \delta(x)
If we allow f be not only normal function but also distribution ##\delta^{a}(x)##
\delta^{a}(x)\delta(x)=\delta^{a}(0)\delta(x)
Let a=-1/2
\delta^{1/2}(x)=\delta^{-1/2}(0)\delta(x)
so it is delta function times the coefficient ##\delta^{-1/2}(0)=0##. So
\delta^{1/2}(x)=0 in the similar sense with
x\delta(x)=0
when multiplied by normal function f of f(0) ##\neq \infty## and integrated.
Long ago I saw the original Colombeau's monography The new generalized functions and multiplications of distributions. I believe it is appropriate.
  • · Replies 25 ·
  • · Replies 20 ·
