Stable oscillation of a blanket in a dryer?
  • Thread starter Thread starter Physics Monkey
    Oscillation Stable
The discussion centers on the observation of periodic motion in a dryer while drying a blanket, which is typically chaotic. The user noted that the blanket exhibited a stable oscillation pattern for about one second, repeating over at least 20 cycles. This phenomenon may occur when the motion of the dryer’s paddles aligns with the blanket's movement, creating a resonance effect. The interaction between the dryer’s drum and the blanket can lead to synchronized motion, resulting in increased noise and vibration. Such observations highlight the complex dynamics of objects in a drying environment.
Physics Monkey
Hi everyone,
Today I noticed something curious while I was drying a blanket in a dryer. The dryer was turning and the blanket was jumbling around as usual, but then I realized the motion was approximately periodic. This periodic motion was strange to me.
Of course, the dryer is driven on a periodic cycle, but in my experience (not that I've really looked very closely), the clothes in the dryer usually move chaotically.
The blanket moved through a variety of shapes and around in the dryer over the course of about one second, then the whole process would repeat. I observed at least 20 periods of roughly the same motion. Afterwards I tried resetting the dryer and shaking the blanket, and when the dryer started again, there was no longer any stable oscillation.
Just curious if anyone else has ever seen something like this or knows anything about it?
It's funny because it really bothered my dog, the appearance of this rythmic and fairly loud beating noise.
Yes I've seen it. Not that I make a habit of staring into a tumble drier :-)
Driers have paddles or blades so objects in the drier are lifted and then allowed to tumble/fall. There are two time constants 1) the drum/blade period and 2) objects period. What I think happens is that under the right conditions these two beat together or get in sync. Perhaps it occurs when the object lands in the same position with respect to a blade each time.
At resonance an oscilating system absorbs the maximium power from the driving source so not surprising if noise and vibration change at resonance.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
