- #1
Spinnor
- 430
Bought a stainless steel whole house water filter for a very good price ($100), turns out too good. On inspection I suspected it would leak so rather then installing it into the house water system I pressure tested it. There was a small leak that stopped after a minute or so. Relieve the pressure and repressureize and the leak came back and stopped as before after a minute or so. I am guessing the o-ring slowly deforms to fill the void in the shell. An image of the unit follows,
The tall can shaped part has a vertical seam weld on the inside that was ground smooth where the o-ring touches but done with a grinding stone with a significantly smaller radius then the inner radius of the shell. I am pretty sure that is where the leak is coming from.
The store I bought it from are willing to take my unit back and replace it with one that hopefully does not leak but I am sure there is a cleaver fix that involves some type of epoxy. The following is how I thought of fixing it where the inside weld of the shell was ground down a bit too much I would apply just the right amount of epoxy, not too much not too little. Then I would cover the epoxy with a piece of rather thickish clear tape and smooth out the epoxy with the straight edge of a credit card. If the tape didn't work the same idea but using a small thin piece of oiled aluminum might do the trick.
I will probably end up shipping it back but if you had to make the repair with a limited tool set what might you do?
Any suggestions for the type of epoxy to use? We have slightly acidic water.
Thanks for any thoughts.
