How does water affect resonance in organ pipes?
The discussion centers on the impact of water on resonance in a closed organ pipe of length 120 cm, resonating at a frequency of 340 Hz. Key conclusions include that the minimum length of the water column for resonance is 50 cm, while the maximum length is 100 cm. The resonance condition for a closed pipe is defined by the equation L = nλ/4, where n must be an odd integer. The participants clarify that the presence of water reduces the effective length of the air column, thus affecting resonance.
  • Understanding of wave mechanics and resonance principles
  • Familiarity with the equation L = nλ/4 for closed pipes
  • Knowledge of the speed of sound in air (340 m/s)
  • Basic concepts of harmonic frequencies in closed systems
  • Research the effects of varying water levels on resonance frequencies in closed pipes
  • Explore the relationship between wavelength and frequency in sound waves
  • Learn about the harmonic series in closed organ pipes
  • Investigate the impact of different lengths of air columns on sound production
Students studying physics, particularly those focusing on acoustics, as well as educators and anyone interested in the principles of sound resonance in closed systems.
palkia
In a resonance tube experiment, a closed organ pipe of length 120 cm resonates ,when tuned with a tuning fork of length 120cm resonates,when tuned with a tuning fork of length 340 hz.If water is poured into the pipe ,then (speed of sound in air=340 ms^-1)
(A) minimum length of water coloumn to have resonance is 50cm
(B) the distance between two succesive nodes is 50 cm
(C)The maximum length of water coloumn to create resonance is 100cm
(D) None of the above
Before the water started filling
Wavelength=Velocity/frequency=1m
For a closed pipe,the resonance condition is
L=n λ/4
Substituting values
4 L/n =1
n=5
therefore - 2n+1=5
n=2
L=3λ/4
I am confused about the next part where there is water flowing into the coloumn.How will it affect the air column now[/B]
palkia said:
L=n λ/4
Where does that equation come from, and is every n possible here?
palkia said:
n=5
therefore - 2n+1=5
n=2
How can you conclude n=2 from n=5?
palkia said:
L=3λ/4
That contradicts the given values.
Initially the tube won't be in resonance.
Where water is there is no air - you reduce the length of the air column.
I made a mess there...only odd values of n will be alllowed there so I should have used a different variable for thatI n any case the value of n will be 3Initially the tube won't be in resonance. (What does this mean)
As far as I understand the problem statement both sides are closed.
I'm not sure what is unclear. A 1.2 m tube, closed on both sides, won't resonate at 340 Hz.
mfb said:
As far as I understand the problem statement both sides are closed.I'm not sure what is unclear. A 1.2 m tube, closed on both sides, won't resonate at 340 Hz.
I think the organ pipe is closed at one end ,that's why n=3.The OP made a typo in my opinion
In that case 120 cm would be close to a resonance.
I am so sorry...it was indeed my mistake
Okay so my length came 1.25 m so what does the extra length tell us??
How should I proceed to do for the water case?Also sorry for my typo...(^|^)
Why is it 1.25 m now when it was 1.2 m before?
What are other possible lengths of the air column where you have a resonance?
Since the L=5λ/4 and putting λ=1 ,I am gettting 1.25m
That is the initial length, with 5 as constant in the formula. 5 is not the smallest possible value here.
12K
