Static Equilibrium components (pulleys, weights)
4 replies · 4K views
fizzsucks
Component diagram:
include all forces, x & y, angles
compare x components (are they equal?)
do y-components equal 0?
Fnet = ma = 0 = F + F + F...
SOHCAHTOA
Attached is my diagram with components drawn in. There are two pulleys with a rope strung across them, with a weight on each end, and one tied in the middle. Weight on the left (100g), middle (120g), right (92g). I need to calculate the x and y components, and see how close they add up to equal 0.
Is the y-component for both vectors = (120g)(9.8)? I thought it should be, however if that's the case, the x-components won't be equal and opposite: (.120g)(9.8)tan54 vs (.120g)(9.8)tan50. And how do I account for the other two weights?
The sum of the two y-components is (120g)*9.8.
To account for the other two weights, note that pulleys change the direction of the tension but not its magnitude.
It is not a matter of dotting your t's and crossing your i's. The numbers for the components are incorrect because you use sine where you should have used cosine and vice versa.
Also Fnet,y = F1y + F2y - mg, where mg is the hanging weight in the middle. The net force is the sum of all the forces and there are three forces at equilibrium in the middle.
