Static friction in body with no intention to move
The discussion centers on the behavior of static friction when a 5 kg block is pushed against a vertical wall with a force of 200 N, given a coefficient of static friction of 0.2. It is established that static friction opposes the applied force until it reaches its limiting value of 10 N, resulting in a reaction force from the wall of 190 N. The conversation highlights the complexities of static friction, emphasizing that the reaction force is indeterminate without additional equations related to material properties and system conditions. The presence of friction alters the force experienced at the wall, demonstrating the intricate nature of statically indeterminate systems.
  • Understanding of static friction and its limiting value
  • Familiarity with Newton's laws of motion
  • Knowledge of statically indeterminate systems
  • Basic principles of force and pressure in physics
  • Explore the concept of static friction limits and calculations
  • Learn about statically indeterminate systems and their analysis
  • Investigate the microscopic origins of friction in materials
  • Conduct experiments on friction coefficients with various surfaces
Physics students, engineers, and anyone interested in the principles of friction and force interactions in static systems.
ash1262
Suppose a block of mass 5 kg is resting on a horizontal surface and coefficient of static friction between block and surface is 0.2.
If the block is pushed against a vertical wall with a force of 200 N, will the static friction oppose the force? The body has no intention of moving as it is pressed against a wall.
What is the reaction on the block by the vertical wall?
Friction always opposes the motion; static friction opposes the imposed force - until the limit is reached. Then the coefficient will change.
If there was no friction the wall would constrain the block. Since there is friction, it must be taken into account.
Update: imagine a pressure sensor on the wall; when there is no friction it would give one reading (force applied / cross section area of the block). With friction the force appearing at the wall will be reduced by the frictional force opposing the motion).
I'm not so sure. If the block cannot even attempt to slide then it looks more like the wall takes all of the force. Perhaps someone with more knowledge than myself could answer this.
For real systems (i.e., not perfectly rigid) both forces will exist. The origin of friction are microscopic interactions at the interface between the materials ... these interactions exist independent of any lateral force ... thus the friction willl be apparent when the block is pushed.
Thus the presence of the wall is a secondary condition - the force at the wall will be the force of the push minus the force of the static friction.
Now consider what happens when the applied force exceeds the limits of the static coefficient of friction!
Thanks, UltrafastPED and Drakkith.
In the case of the block, since the limiting value of the static friction is 5*10*0.2=10N, the reaction from the wall should be 190N.
I wonder if someone in the forum can conduct an experiment to confirm/demonstrate this phenomenon.
Experiments are left as homework for the student! :-)
Dear DaleSpam,
Does that mean that we can not assume that the static friction will be at the limiting value?
Thus, as the friction can take any value, the reaction from the wall is indeterminate?
Can we not rig up an experiment using different surfaces with different coefficients of friction, and measure the reaction from the wall, keeping the surface horizontal and the wall vertical?
ash1262 said:
Dear DaleSpam,
Yes and yes.
We can, but it won't help. Consider that if the force pushing the block towards the wall is high enough, we could remove the floor and the block would still be fixed in place against the wall; that is, the characteristics of the floor including surface and coefficient of friction are irrelevant to the outcome under some conditions.
If you carefully review the Wikipedia article on statically indeterminate systems you will find this statement:
"Considerations in the material properties and compatibility in deformations are taken to solve statically indeterminate systems or structures."
This is why I took into consideration the microscopic origins of friction, and also discarded the "rigid body" idealization. And yes, a real experiment could be performed.
Agreed, a real experiment could be performed. But the scenario being described here does not pin down a set of conditions sufficiently so that all possible matching experiments would produce a similar definite outcome.
No real experiment can answer the question that is being asked. The correct answer is: "it depends".
It means that the system, as described, has more unknowns than equations. To solve it you need to get more equations. The additional equations come from the details of the shape and material properties.
Until you push the block there is no reaction force from the wall, or from friction. So imagine you start pushing at t=0... Which kicks in first? The reaction force from the wall or the friction? It can't be determined.
  • · Replies 20 ·
  • · Replies 18 ·
  • · Replies 16 ·
