Statics problem -- Frame supported by pin connections....
The discussion revolves around a statics problem involving a frame supported by pin connections. Participants explore the analysis of forces, tension and compression in members, and the calculation of reactions at specific points. The focus includes free body diagrams, trigonometric relationships, and the implications of forces acting on the structure.
  • One participant questions whether to include both y components and tension at point B when calculating reactions, suggesting that both components may be necessary for a complete analysis.
  • Another participant proposes a method of visualizing tension and compression by considering the movement of points B and E if a member is removed, raising questions about the nature of forces in the members.
  • A third participant emphasizes the importance of recognizing pinned diagonals as 2-force members, indicating that the forces are related through trigonometric functions.
  • One participant expresses concern about the results being too low and questions the correctness of their trigonometric calculations in the moment equation.
  • Another participant agrees with the equation but cautions about the assumptions made regarding the direction of vertical components, suggesting that negative results may indicate an incorrect assumption about force direction.
Participants express various viewpoints on the analysis of forces and the application of trigonometry, with no consensus reached on the correct approach or calculations. Disagreements exist regarding the assumptions made about force directions and the interpretation of results.
Participants note potential typos in the problem statement and emphasize the need for careful consideration of force directions and components in calculations. There are unresolved aspects regarding the accuracy of trigonometric applications and the implications of negative results.
Subba
Problem is here,
http://s24.postimg.org/3y6wpyncl/frame.png
I'm looking at this problem with the top and bottom beams being separate members and doing a FBD of both separately. However I'm unsure about the points where we have tension/compression. Like at point B, do I include a y component and the tension, or just tension? My first instinct was to not include the y component by itself, but the problem asks to find the reactions at point B, so wouldn't that need to be broken down into x and y?
Doing the latter, what I was thinking is taking a moment about D and going from there.
MD = (0.8)TBEsin51.3 + (1.2)TFCsin68.2
I would then solve for one of those variables, take the moment about A in the other diagram, and and plug in. Would that be correct?
Also, for distributed force, would it be 400(1.4), with the distance being it is acting on the top member be [400(1.4)][0.7]?
Thanks
I'm not an expert here, but my first thoughts are:
As far as tension or compression goes, I try removing that link (eg. BE) and ask how the ends would move (eg. would B and E become closer or further apart?) From the geometry and load one can often see what would happen.
Looking at this diagram, I ask myself, can they both be in compression? Or both in tension? How would that affect the bottom beam?
Looking at this problem, I would think about x and y components because you will be able to ignore one or other in some calculations: for eg. when you take moments about D, you can ignore y at A and x at E and F. It will also remove sines and cosines from some calculations.
Perhaps you can share more of your thoughts, then people are able to make more pertinent comments.
BTW I think there may be a typo in the question, as there does not seem to me to be a "member ABD". I am assuming they mean ABC.
P#3 is worded strangely for me. I would work out the horizontal and vertical components, then the magnitude and direction of the total force.
Yeah correct the typo.
You should note that the pinned diagonals which are subject to forces at either end with no forces in between are thus 2-force members, subject to resultant axial forces along the member in tension or compression. Therefore, the x and y components of the tension or compression forces are trig related sines or cosines of the axial force. Draw free body diagrams of each beam and solve for unknowns.
I solved the problem the way I think it's suppose to be solved, but the numbers I'm getting seem way too low, so I screwed up somewhere. Is my trigonometry correct in this equation?
MD = (0.8)TBEsin51.3 + (1.2)TFCsin68.2 = 0
Equation looks good but remember that in writing it you have assumed that both vert components of BE and FC forces act in the same direction. That's ok. Now when you look at the top beam, you must assume that those vert force components being equal but opposite per Newton act in the opposite direction. Then when you solve for them, if a result comes out negative, you assumed the wrong direction, and must make appropriate adjustments. Please show your full calcs for better assistance. The minus sign and it's interpretation will bury you if you are not careful.
