Statistical physics: counting states, entropy and temperature
This discussion focuses on statistical physics, specifically the relationship between entropy, temperature, and the distribution of particles in a system of N identical but distinguishable particles with a nondegenerate ground state and a g-fold degenerate excited state. The key equations include the entropy formula S(E,N) = k ln Ω(E,N) and the temperature relation 1/T = (∂S/∂E)_{V,N}. The challenge lies in inverting the temperature function T(ν), where ν = M/N represents the fraction of excited particles, which is complicated by the non-invertibility near ν=1. The discussion also touches on the implications of negative temperature systems in thermal contact with positive temperature systems.
  • Understanding of statistical mechanics concepts such as entropy and temperature
  • Familiarity with Stirling's approximation in combinatorial calculations
  • Knowledge of thermodynamic limits and large systems
  • Proficiency in mathematical functions and their inverses
  • Investigate the implications of negative temperature in statistical mechanics
  • Learn about the derivation and application of Stirling's approximation
  • Explore the concept of thermodynamic limits in large particle systems
  • Study the graphical representation of functions and their invertibility in statistical physics
Students and researchers in physics, particularly those focusing on statistical mechanics, thermodynamics, and entropy analysis. This discussion is also beneficial for anyone interested in the behavior of systems with negative temperature and their thermal interactions.
EricTheWizard
Hi everyone, I've hit a bit of a snag with part c of this problem (can't figure out how to invert a function T(ν)), so I'm starting to question whether I have the previous parts correct.
Consider a system of N identical but distinguishable particles, each of which has a
nondegenerate ground state with energy zero, and a g-fold degenerate excited state with
energy ε > 0.
(a) Let the total energy of the system be fixed at E = Mε, where M is the number of
particles in an excited state. What is the total number of states (E,N)?
(b) What is the entropy S(E,N)? Assume the system is thermodynamically large. You
may find it convenient to define ν ≡ M/N, which is the fraction of particles in an
excited state.
(c) Find the temperature T(ν). Invert this relation to find ν(T).
(d) Show that there is a region where the temperature is negative.
(e) What happens when a system at negative temperature is placed in thermal contact
with a heat bath at positive temperature?
entropy: [itex]S(E,N) = k \ln \Omega (E,N)[/itex], where [itex]\Omega[/itex] is the number of states with energy E and particle number N.
temperature: [itex]\frac{1}{T} = (\frac{\partial{S}}{\partial{E}})_{V,N}[/itex]
Stirling's approximation: [itex]k! ≈ \sqrt{2\pi k}e^{-k}k^{k}[/itex]
a) A particle can be in either the ground state or one of g excited states, so the number of states with excited particle number M should be [itex]\Omega(M,N) = {{N}\choose{M}} g^M[/itex] because there are [itex]{N}\choose{M}[/itex] ways to arrange which particles in an ensemble are excited, and then g choices for each particle of which degenerate state they're in. This seems to make sense to me, anyways.
b) To find the entropy, simply take the natural logarithm of Ω (which requires you to make Stirling's approximation so that you can pull parts of the factorials through the log)
[tex]S = k \ln\Omega ≈ k \ln{(\frac{N^{N+1/2}g^M}{\sqrt{2\pi}(N-M)^{N-M+1/2}M^{M+1/2}})} = k[(N+1/2)\ln N + \frac{E}{\epsilon}\ln g - \frac{1}{2}\ln(2\pi)-(N-\frac{E}{\epsilon}+\frac{1}{2})\ln{(N-\frac{E}{\epsilon})}-(\frac{E}{\epsilon}+\frac{1}{2})\ln{\frac{E}{ε}} ][/tex]
c) Now find the temperature distribution [itex]T(\nu)[/itex] making the substitution [itex]\nu = M/N = E/N\epsilon[/itex], the fraction of particles in the excited state and using the formula for temperature given above.
[tex]\frac{1}{T} = \frac{\partial S}{\partial E} = \frac{k}{\epsilon}[\ln g + \ln(N - E/\epsilon) + \frac{N-E/\epsilon+1/2}{N-E/\epsilon}-\ln\frac{E}{\epsilon}-(1-\frac{\epsilon}{2E})] = \frac{k}{\epsilon}[\ln\frac{g(1-\nu)}{\nu}+\frac{1}{2N}\frac{2\nu-1}{\nu (1-\nu)}] = \frac{1}{T(\nu)}[/tex]
Now this is the part I'm stuck at; I simply can't invert T(ν) because it's not a 1-to-1 function. If you plot it in Mathematica or similar, you get something like this:
which (and you can't see this very well) turns downward near ν=1 very sharply and makes the distribution non-invertible (at least in the negative temperature zone). Have I made a mistake somewhere?
d) Set T<0 and solve for the pertinent conditions (haven't tried this yet)
e) Heat will flow from a negative temperature system to a positive temperature one if they come in contact.
EricTheWizard said:
[tex]\frac{k}{\epsilon}[\ln\frac{g(1-\nu)}{\nu}+\frac{1}{2N}\frac{2\nu-1}{\nu (1-\nu)}] = \frac{1}{T(\nu)}[/tex]
Just a thought: Can you ignore the second term on the left if you assume N is large?
You're right; the problem does say to assume the system is thermodynamically large (N order of 10^23 or whatever). Sounds like a valid strategy (and makes the answer [itex]\nu(T)=\frac{g}{e^{\epsilon/kT}+g}[/itex]).
Thanks for the inspiration!
