Statistics: variable transformation proof?
The discussion revolves around proving the relationship between random variables Y and X, specifically when Y is defined as a transformation of X, denoted as Y = u(X). The user seeks clarification on how to demonstrate that the probability distribution of Y, g(y), relates to the distribution of X, f(x), through the inverse function w. A key point highlighted is the importance of the one-to-one nature of the transformation; if u is not monotonic, the relationship becomes more complex. The conversation emphasizes that understanding the mapping and its implications on probability distributions is crucial for accurate proof. The thread concludes with an acknowledgment of the need for careful evaluation in cases of non-monotonic functions.
Nikitin
Ok this might be a stupid question, but:
https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-frc3/t31/q77/s720x720/10001118_10202561443653973_1625797585_o.jpg
Why is this the case? I think for all of this to be right, then the assumption of ##Y=u(X) \Leftrightarrow y=u(x)##. But how do I prove this?
An attempt: OK, assume ##X## has a probability distribution given by ##f(x)##, and ##Y=2X## has a probability distribution of ##g(x)##. Then if ##Y = u(X)##, with w being the inverse one-on-one function of u, ##P(X=x) = P(w(Y)=x) = P(Y=u(x))=P(Y=y=u(x))##.
This is as far as I got, but now I am confused. What to do?
You're almost there. Note by definition that
g(y) = P\{Y = y\}
and you must prove that
g(y) = f(w(y))
which is by definition
f(w(y)) = P\{X = w(y)\}
So you must somehow find why
P\{Y = y\} = P\{X=w(y)\}
Likes 1 person
OK, I see. Thanks for the help :)
You already got the answer below, but just to clarify: the one-to-one assumption is crucial. If you had a non-monotone function, such as ##u(x) = x^2##, and if the range of ##X## included both positive and negative values, then the mapping ##Y = u(X)## might not be 1:1, and so you might need a more complicated evaluation of ##P(Y = y)##.
Likes 1 person
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
