What is the method for deriving Stokes' law for drag around a sphere?
The discussion centers on deriving Stokes' law for drag around a sphere, specifically the equation F=6πnau, where n is the fluid's viscosity, a is the sphere's radius, and u is the fluid's velocity. The method involves calculating the viscous stress tensor to determine the stress vector on the sphere, which is integrated to find the drag force. It is established that pressure integration does not yield the correct drag force in Stokes flow, as the pressure contributions cancel out, leaving only viscous drag as significant in this low Reynolds number scenario.
  • Understanding of Stokes' law and its application in fluid dynamics
  • Familiarity with viscous stress tensors and their role in fluid mechanics
  • Knowledge of spherical polar coordinates and their application in physics
  • Basic principles of Reynolds number and its significance in flow regimes
  • Study the derivation of Stokes' law in detail, focusing on viscous stress tensors
  • Explore the implications of Reynolds number on flow behavior around spheres
  • Learn about pressure drag in inviscid flow and its differences from viscous flow
  • Investigate the relationship between flow attachment and drag forces in various fluid regimes
Students and professionals in fluid dynamics, mechanical engineers, and physicists interested in the principles of drag forces and flow behavior around objects in viscous fluids.
fayled
So you can solve the Stokes equation for flow around a sphere to obtain the pressure in the fluid:
p=p0-3nuacosθ/2r2
where n is the viscosity, u is the speed of the fluid (along the z axis) far away from the sphere, a is the radius of the sphere and r,θ are the usual spherical polar coordinates.
We can also obtain an expression for the velocity field u=(ur,uθ,0) which I won't type here because I'm only concerned about the general principles of something.
My question is about the method for deriving Stokes' law for drag, F=6πnau. The method I have seen is to use the velocity field to work out the viscous stress tensor, which allows you to compute the stress (as a vector) on the sphere due to the fluid. This vector can then be integrated over the sphere to give the required drag force.
However, I don't understand why we can't just integrate the pressure*(-r/r) i.e multiplied by its direction of action on the surface of the sphere, the radial unit vector, and integrate this over the sphere to give the drag force. I have tried and it doesn't seem to give the same result (you don't need to perform the integral, only need notice that the stress vector and the vector obtained from the pressure are not equivalent).
Thanks for any help :)
If you integrate the pressure around the surface in Stokes flow you should get zero. The pressure on the front and back should exactly cancel, if I recall. The only form of drag on a sphere in Stokes flow is viscous, and since viscous drag has nothing to do with the pressure, it shouldn't surprise you that you can't derive it from the pressure distribution.
After all, look at the pressure equation you cited. If you integrate that over ##\theta = [0,\pi]##, you get zero.
Ok - it doesn't surprise me that it's to do with the flow being viscous as opposed to inviscid, as I have used the pressure approach to find say the lift in inviscid flow. So why exactly does pressure give rise to drag and lift in inviscid flow and not viscous flow?
It gives rise to drag in viscous flow, it's just that Stokes flow is a special case. The Reynolds number is so low that the flow remains attached around the sphere the entire way. In general, this is not the case. If you had a higher Reynolds number, you would end up with a wake behind the sphere with a lower pressure than in front of it, thus resulting in pressure drag.
I think this is incorrect. The pressure drag around sphere for potential flow is zero.
For Stoke's flow you have contribution from friction (2/3) and pressure drag (1/3).
http://user.engineering.uiowa.edu/~fluids1/Creeping_flow_1.pdf
  • · Replies 28 ·
  • · Replies 18 ·
  • · Replies 32 ·
