Stoke's Law - Method and how to do it - graph?
  • Thread starter Thread starter zkm1223
    Graph Law Method
This discussion focuses on applying Stoke's Law to determine the viscosity of glycerol using different ball bearings. Participants outline a method involving measuring the terminal velocity of the balls as they fall through glycerol, using a glass tube with marked intervals. The key formula discussed is the slope of the graph of R² versus terminal velocity, which is used to calculate the coefficient of viscosity (μ) based on the equation m = 2/9*[ρ(b) - ρ(gl)]*g/μ. The density of the ball bearings is assumed constant if they are made from the same material.
  • Understanding of Stoke's Law and its application in fluid dynamics.
  • Familiarity with measuring terminal velocity in a viscous medium.
  • Knowledge of graphing techniques, specifically plotting R² versus terminal velocity.
  • Ability to perform density calculations for different materials.
  • Learn how to accurately measure terminal velocity in a viscous fluid.
  • Study the derivation and application of Stoke's Law in various contexts.
  • Explore graphing techniques to analyze data from experiments involving fluid dynamics.
  • Research the properties of glycerol and its viscosity characteristics.
Students conducting experiments in physics, particularly those focusing on fluid dynamics and viscosity measurements, as well as educators teaching concepts related to Stoke's Law.
zkm1223
Hi, i have to write a method to do stoke's law on different ball bearings and draw a graph of stoke's law of different ball bearings in glycerol and from the graph i have to find the viscosity of the liquid. How do i do this?
I have the top 2 formula's from:
http://en.wikipedia.org/wiki/Stokes'_law
Don't know where to start, so please help. thanks in advance.
Find radii of different balls. Find their terminal velocities. Draw a graph of R^2 vs terminal . It will be a straight line. From the Slop of this line can find the coefficient of viscosity.
thanks for your reply. so i measure the diameter using a micrometer, then halve to get radius. but how do i find terminal velocity and is the viscosity the gradient of the line? will it be the same for all ball bearings? also what are the formulas for?
The terminal velocity will be different for different balls.
Take a glass tube of 5 cm diameter. Fill it with glycerol. From liquid level make 5 cm marks on the tube.
Drop a ball bearing. Start the stop watch when the ball enters the liquid. Note down the time whenever the ball crosses the 5 cm mark. When the time interval (t) becomes constant, the terminal velocity will be 5cm/t. Find the densities of the ball and liquid by any method. Using second formula find coefficient o viscosity. of glycerol.
I think you draw terminal vs r^2 i.e terminal on the y-axis and radii on x axis?
Yes. Slope of the graph m = 2/9*[rho(b) - rho(gl)]*g/mu, where mu is coefficient of viscosity. From this you can find mu.
The problem i have with this is that once one has found the gradient of the graph and thus deciphered the value of the constant k, which value would one use for the density of sphere as they all vary
If the material of the ball bearings is same, then the density of them will also be the same.
I get that k is the gradient, however this doesn't make sense to me:
Can you explain further please?
ahh i realized after i posted the question how stupid i was, ofc the density doesn't change its the same material !
when you found k, use this equation http://upload.wikimedia.org/math/3/d/b/3dbef61d20c1951c09a727ff8d4a809c.png, where k is equal to Vs to find the value of u which will be the viscosity of the material
when you found k, use this equation http://upload.wikimedia.org/math/3/d...ff8d4a809c.png , where k is equal to Vs to find the value of u which will be the viscosity of the material
But aren't we looking for the coefficient of viscosity, not viscosity itself? Because the experiment is investigating stokes law, which is F = 6 x Pi x r x coefficient of viscosity x v.
If k = viscosity, we aren't finding the coefficient. Or am I just getting really confused and over complicating it? (I have a feeling I am).
dfgdfg
quinox3o0o said:
sorry let me start again, the value of the gradiet is equal to the value of Vs in the equation, http://upload.wikimedia.org/math/3/d/b/3dbef61d20c1951c09a727ff8d4a809c.png, the letter U represents coefficient of viscosity, so rearrangement and you have your answer.
Btw are you doing this for some sort of cw?
Ok, that makes more sense; thanks. And yes I am. I'll use this thread as a source for calculating and describing the graph, shouldn't be a problem.
  • · Replies 29 ·
