Calculate Stress & Strain from Length, Diameter & Load
The discussion focuses on calculating tensile stress and strain for a cylindrical material with a length of 50mm, a diameter of 12mm, a load of 11.5 kN, and an extension of 0.025 mm. The tensile stress is determined using the formula stress = force/area, where the area is calculated from the circular cross-section. The strain is calculated as the extension divided by the original length, expressed as a percentage. Understanding these calculations is essential for accurately assessing material behavior under load.
  • Understanding of tensile stress and strain concepts
  • Knowledge of circular cross-sectional area calculations
  • Familiarity with basic mechanics of materials
  • Ability to perform unit conversions (e.g., kN to N)
  • Learn how to calculate circular cross-sectional area for tensile stress
  • Study the relationship between load, stress, and strain in materials
  • Explore the concept of Young's modulus and its applications
  • Investigate the effects of different materials on stress and strain calculations
Engineers, materials scientists, and students studying mechanics of materials who need to understand stress and strain calculations in cylindrical materials.
Chuck Finley
No template because submitted to wrong forum
Unsure how to calculate in order to get the stress (N/mm2) and strain (%) if:
a material has a length of 50mm
diameter of 12mm
Load: 11.5 kN
Extension 0.025 mm
Help on how to work this out would be very appreciated :)
Note the forum guidelines insist you show some attempt but let me see if I can get you started.
You need the mental picture of, I think in this case, tensile stress and strain. It appears as if the material is cylinderical so has a circular cross sectional area. Note that the stress units are force per area. Double check your textbook on the definition of stress. [If you haven't a clear idea of its definition you should not have started this problem yet.]
Secondly the cylinder has a length (50mm) and that is extended by the strain produced by the force (the extension amount) and so % strain should be an obvious calculation. Note that tensile stress extends along the entire length of a wire or rod so doubling the rod is equivalent to stacking two rods so doubling the length should double the strain for the same material and stress. Strain is proportional to the length in other words so it makes sense to express it as a proportion change.
[Again this is something you should understand before attempting the specific problem.]
  • · Replies 29 ·
  • · Replies 17 ·
