String theory in one sentence please
The discussion revolves around how to succinctly describe string theory in a single sentence, particularly in the context of its relevance to the Large Hadron Collider (LHC). Participants explore various definitions and perspectives on string theory, touching on its theoretical implications and criticisms.
  • Some participants propose that string theory constructs a framework in higher dimensions from which particles and interactions emerge, while noting the complexity and lack of consensus on its uniqueness.
  • Others argue that string theory is a failed attempt to describe everything without experimental backing, suggesting it is merely a mathematical exercise.
  • A participant highlights that every physical theory has its limitations and domains of applicability, questioning the validity of starting from ungrounded postulates.
  • Some contributions emphasize the mathematical nature of string theory, with claims that it is built on physical principles, while others challenge this characterization as overly simplistic or ignorant.
  • There are mentions of the anthropic principle and selection principles in string theory, indicating differing views on its interpretative frameworks.
  • A participant draws parallels between string theory and other theories, suggesting that criticisms of string theory could apply to many scientific theories.
Participants express a range of views on string theory, with no clear consensus. Some support its theoretical framework, while others criticize its empirical validity and foundational assumptions.
Participants note the complexity of string theory and its implications, as well as the challenges of conveying these ideas in a simplified manner for non-technical audiences. There are also discussions about the limitations of theories and the nature of scientific understanding.
  • #31
Demystifier said:
Maybe we are not talking about the same posts. I am talking about the first one on this thread.
Anyway, if the homework is not to explain what string theory is, but to explain why string theory is bad, then I agree that the mentioned summary was good.
There two aspects of the OP: what is a string in the string theory and does it work?
  • #32
Bob_for_short said:
And GR experience is, of course, a perfect model for following, isn't it?
Exactly!
Bob_for_short said:
You know, transition to an accelerated reference frame does not change the geometry, in particular, the space or space-time curvature R. It is true in both Galilean and Minkowski space-times. Introduction of the space-time curvature (i.e. a Riemann space-time) was not necessary to describe the gravity in the relativistic theory.
Agree.
Bob_for_short said:
Rejection of the plane (Minkowski) space-time in GR means at least:
1) Rejection of additive conservation laws,
2) Describing the gravitational filed as a geometrical feature of space-time rather than as a physical field, for example, carrying the energy-momentum when radiated.
Agree.
Bob_for_short said:
At the same time the theory can be formulated in the Minkowski space-time without loosing the conservation laws and with describing the gravity as a physical field (RTG of A. Logunov’s). Do you feel a difference?
Yes I do. Still, I prefer GR because it is simpler.
Bob_for_short said:
Is there any experiment contradicting the additive conservation laws?
Is there any experiment contradicting GR?
Bob_for_short said:
Another bright example of postulating or axiomatization of something physically non-motivated. Indeed QED has conceptual and mathematical difficulties. It does not work without renormalizations. The local gauge invariance principle leads exactly to these difficulties. Yet one generalizes it to other symmetries, and why? In order to introduce interaction. But there are other ways of introducing interaction and the "gauge" way is not the only one.
Do you know an example of another way of introducing interaction that agrees with experiments in particle physics?
Bob_for_short said:
Now, we have to live with those singularities, worm holes, and rotten apples as if it is something inevitable.
No we don't. The mainstream view is that GR is only an approximation. True, we still do not know the exact theory without singularities and other pathologies. Perhaps it is something like Logunov theory. Or perhaps it is something more similar to GR. Or perhaps it is something completely different.
  • #33
The question "does it work" is too vague. You may say that it doesn't work because it does not yet lead to a quantitative prediction testable with current technology. Or you may say that it works because it avoids ultraviolet divergences, qualitatively predicts the observed gravitational and gauge interactions, and is not in contradiction with existing experiments. The truth is somewhere in between.
  • #34
Demystifier said:
...Still, I prefer GR because it is simpler.
You yourself mention "singularities and other pathologies" that are absent in RGT. How can we count on a theory with pathologies? How can we compare the gravitational effects if they belong to different geometries? Do you like a geometry varying with time?
In QED, yes, see my publications where I outlined such a way. It is quite physical.
  • #35
We can use it for weak fields where pathologies are absent.
I don't quite understand what are you pointing out here.
Have you calculated g-2 in your theory? Have you also achieved an agreement with experiments up to 10 decimals (as QED has)?
  • #36
So here a single-sentence characterization:
String theory is a physical model based on tiny strings that incorporates both quantum mechanics and general relativity and attempts to unify gravity with particle physics.
  • #37
Only weak field effects are not sufficient to "prove" or prefer the entire GR.
Not yet. No one can fulfil the forth order QED calculations in one article.
By the way, agreement "up to 10 decimals" and even better can be obtained for any normal function developed in Taylor series up to the fourth order with the small parameter of about 0.001 ( ≈ α/2π ). There is too much exaggeration about predictive force of QED in this respect.
  • #38
With that I agree.
I wish you a good luck.
But the problem is that in QED you do not know this "normal function" explicitly.
  • #39
Thanks. You know, for some Lagrangians it is sufficient to prove renormalizability to start working with them seriously. In my case the theory is divergence-free which is much better than renormalizability.
...the problem is that in QED you do not know this "normal function" explicitly.
That's right. QED has tought us many wonderful things and I really hope it's not finished yet.
By the way, I encountered a case (not in QED) when the exact function is known explicitly but its Taylor series does not coincide with the perturbation theory expansion! See formula (A3.5) and page 16 in arXiv:0906.3504.
  • #40
String theory is an attempt to mathematically unify quantum mechanics and general relativity by using strings vibrating in multiple spatial dimensions as the fundamental building blocks of the universe.
  • #41
Bob_for_short said:
The question remains: why strings? Screws are much better for unifying.
Screws do not predict gravity and gauge interactions.
Screws do not avoid UV singularities.
  • #42
Chronos said:
String is a purely mathematical attempt to model reality. It is not provably wrong [and may never be], but, empirically unsatisfying thus far. It explains some observations, mostly at the quantum level, but otherwise has no compelling observational support.
Edit
String is a purely mathematical attempt to model reality. It is not provably wrong [and may never be], but, empirically unsatisfying thus far. It has no observational support.
  • #43
Thanks Marcus, It's an essay that nobody in my class will understand so i won't be graded down on it, but I am very interested in knowing more about the subject and where I went wrong. I was under the impression that when they smashed the particles together, there might be a loss in mass, and the mass had to go somewhere, so into another dimension? I am not sure I am only 17 so you guys obviously know way more about it than I do, any more info would be appreciated, and thanks again Tom for your summary. (Thanks to everyone else also contributing to the post too).
  • #44
Congratulations to you for keeping with us and surviving all these discussions.
I would still propose my explanation as a starting point
"String theory tries to construct a supersymmetric framework in 10 dimensions from which all known elementary particles and interactions including gravity should emerge from the modes of an one-dimensional, vibrating string."
but of course I agree with many aspects mentioned by others, especially (some changes from my side to achieve the one-sentence goal)
"It is a purely mathematical attempt to model reality which is not provably wrong [and may never be], but, empirically unsatisfying thus far and w/o any observational support."
I think those two statement could be the core of your talk or small paper or whatever. Then you have to explain a bit what it means ...
  • #45
"String theory tries to construct a supersymmetric framework in 10 dimensions.."
In four dimensions as well, of course... ever heard about that ?
" purely mathematical attempt "
What means "purely" mathematical? Of course there are physical principles built in, like quantum mechanics, actions, scattering amplitudes etc... in particular it is based on the physical picture of a string, and the action is a manifestation of that. How can one call this pure mathematics? Are other theories of quantum gravity (I should say much less founded attempts) any less "mathematical"?
I suspect "purely mathematical" simply needs to be translated "incomprehensible to me".
Why people who have no idea about this subject confuse the discussion with second hand opinions and misleading, if not outright incorrect statements. No wonder why any expert in this field is driven out from this forum here. Good bye.
  • #46
Tom, I think your sentence would be much better, at least for "normal" people, if you just replaced the word "supersymmetric" with "mathematical".
I'm not crazy about Finbar's sentence. I think it's pretty misleading actually.
a) it's misleading to call it "purely mathematical"
b) words like "unsatisfying" are very subjective shouldn't be included in a brief explanation of what the theory says
c) the fact that you're not floating away from the chair you're sitting on is experimental support for string theory, so you should find a better way to express your thoughts about the experimental situation.
A few comments about a): There's no such thing as a purely mathematical theory, and a mathematical model is always purely mathematical. A theory consists of a mathematical model and a set of axioms that tells us how to interpret the mathematics as predictions of results of experiments. It's OK to say that string theorists are trying to find an appropriate mathematical model, and that their work at this time is therefore "purely mathematical", but if they don't ever do anything more than that, it won't ever be a theory. So it's wrong, or at least misleading, to talk about string theory as a "purely mathematical attempt". What they're attempting to do is certainly more ambitious than to just find some cool mathematics.
  • #47
The problem is that the UV divergence of QG is managed with some cut-off (string size) and a great deal of physical meaning is given to it without experimental evidence whereas a cut-off is just an awkward stop-gap.
  • #48
suprised said:
"In four dimensions as well, of course... ever heard about that ?
The space in which strings move is 10-dim. Everything else is refinement, solving the equations, constructing vacua etc. The starting point and one of the core problems is that it's 10-dim. One does not know how to select the "correct" vacuum = our universe in 4 dim. And one does not even know why 6 dims are compactified; why not less or more?
It's quite simple. w/o suport from experiments it is a mathematical exercise, not phsics. It will become a physical theory if it either post-dicts some already know particles, masses, coupling constants etc., or if it makes at least one falsifiable prediction.
As long as physical predictions atre missing they suffer from the same problems.
If they are not willing to participate it's not my problem. The problem is neither that we are talking about weaknesses of the theory nor that the theory has weaknesses. The problem is that the experts are partially not willing to even accept that these issues exist. Best example is the finiteness of the theory: there's the claim that ST is finite in all orders PT. The problem is that beyond 2 loops there is not even a definition of the amplitude!
  • #49
I think the problem with describing string theory in one sentence is there isn't exactly just one "string theory". 1990s string theory is somewhat different from modern M-theory is different from AdS/CFT. I'd attempt something like:
"String theory" refers to a group of related research programs, which share the starting point of suggesting things that appear to be particles can be thought of as a side-effect emerging from the vibrations of one-dimensional strings.
And then explain what this has to do with the LHC.
Researchers believe that if string theory is real and not just a quirk of mathematics, particles must be "supersymmetric": this means every type of particle has a rare "superpartner" which has so far never been seen, but which the LHC would probably be able to find.
That sound about reasonable?
  • #50
I agree with the first sentence; its focus is slightly different, so if it could me merged with mine it would be OK.
Regrading the LHC there's a problem: if the LHC finds SUSY this is a hint for a support of strings, NOT a proof (SUSY / SUGRA could exist even if ST does not); if the LHC does not find SUSY it simply may be there at even higher energies. So either way ST could survive by making the right turn - and that's the core roblem with it: anything goes ...
  • #51
Now that I am done with this retarded essay that I got a B on (the only coment on the entire essay said "too technical") quite a few months ago, maybe we can continue to talk about this? If anyone has anything else to say that is...
  • #52
Your teacher has given you a trick question; since the sad truth is that string theory
has never been stated in one sentance or in a thousand sentaces! You will learn
nothing about physics in it, but you can learn much about the social and psychological
forces at work in modern day university science.
String theory is now over 30 years old, and has yet to make a single testible prediction.
Articles in the popular press about LHC testing string theory are hype. Piles of books, and reams of video documentaries boil down to jibberish. Even with a high school education
you can watch "The Elegant Universe" and see the lack of any real science content.
Those that so despirately promote the theory are usually trying to defend their
job position.
But the real importance of string theory is the lasting damage it has done to physics and
science in general. The accepted rules of the scientific method have been thrown out
the window.
To see how absurd things have gotten, read up on the "Anthropic" principle.
Also take a look at the books written by Peter Woit and Lee Smolin, and see how
violently they have been attacked by the string community!
Woit's blog is a good place for a reality check:
http://www.math.columbia.edu/~woit/wordpress/
  • #53
I agree that the strong and weak anthropic principles are one of the most rediculous things I have ever read about but I'll have to check out Woit's blog.
  • #54
Again: here's my proposal:
String theory tries to construct a supersymmetric framework in 10 (11) dimensions from which all known elementary particles and interactions including gravity emerge (uniquely) from the modes of an one-dimensional, vibrating string.
Questions:
- what was your porposal?
- what was your teacher's proposal?
  • #55
It was just an analysis of the LHC and I wanted to include a part about how it was a possible test for string theory but she told me I had to define SR in one sentence or it would be too technical...
  • #56
String theory is ridiculous.
Hardly a sentence
  • #57
I will offer a simpler, and somewhat philosophical explication of what, I believe, Superstring theory represents. It also causes me to be convinced that the basic idea of the theory pretty much has to be right!
At base, I think it represents the resolution of a confusion about the relationship of mathematics to physics. Physics requires some physical extension in "reality"; whereas math is pure theory. In math, one commonly utilizes the idea of dimensionless points. Physics, which is so used to importing ideas from math, seems to have forgotten the philosophical difference between the 2 disciplines. It began utilizing the idea of "point-particles" ---which were conceived of as "dimensionless"; i.e. without physical extension. To my mind, with Superstring theory physicists (through extremely difficult mathematics) finally "came to their senses".
Physics is a discipline, unlike mathematics, where some physical extension is absolutely necessary. Thus, it was never possible that there could have been such thing as "dimensionless" "point" particles. Though subatomic "particles" are conceived to be the smallest possible "things", they still need to have some physical extension in order to "exist" in "reality". Superstring Theory, philosophically, recognizes that the smallest possible physical extension must be a one-dimensional entity (once you accept that "dimensionless" cannot be a physics construct, there must be at least one physical dimension in play). Yet, of course, the most basic physical entity must also be the "smallest possible" one-dimensional entity.
Now, most people would believe that there is no such thing as the smallest possible thing. One would logically assume that "you can always cut it in half" and get something smaller. This logical assumption is very similar to the belief that, however fast something is moving, it can always go a little faster. Einstein proved, at the time shockingly, that the latter assumption was wrong. You cannot always go a little faster. The universe has a "speed limit", and nothing can ever accelerate to the speed of light. Yet few people realize that, just like the false assumption about speed, so our assumption that there is no limit to smallness is also wrong.
All physicists realize that the is a limit to smallness ---it is called Planck Length. So, at last, we can reasonably talk about "least possible physical extension" as a meaningful physics construct replacing the construct of "dimensionless" mistakenly imported from mathematics. The simplest physics entity that could ever "exist" would be a one-dimensional entity of Planck Length. Is it, then, surprising that this turns out to be the very definition of a Superstring?
Lo and behold, when the universe is viewed in terms of this simplest of all physical construct, we see the very term "particle" becomes replaced by the more accurate metaphor "string". Then we suddenly see that the vast "zoo" of physics entities formerly called "particles" are understood as Superstrings vibrating differently in 6 dimensions (within a larger 11 dimensional hyperspace).
As has been said often, each different string vibration is like a different musical note. Like one guitar string can create a B flat, an F#, or a myriad of other notes; so each superstring can vibrate to create of create a myriad of subatomic structures ---photons, electrons, neutrinos, gravitons, etc.
Anyways, that's the simple way I think of Superstring Theory such that it seems to me so obviously right.
  • #58
Bob_for_short said:
String theory is another failed attempt to describe everything without any experimental background.
To my knowledge, this is the best description of string theory.
  • #59
I did some graduate student research on superstring theory, but I lost my enthousiasm for doing any more research in this topic totally.
I also do mathematics, but a lot of mathematics, used in many of the articles I had to study, isn't always used in a clear way. It took ages to realize it's not my fault I didn't understand some parts.
  • #60
This is of course an exaggeration and a gross misrepresentation of the situation. Has anybody proved that string theory is not provably wrong? Of course not. The fact that people haven't been able so far to make testable predictions does not prove that it will never happen. I think it is wrong to mislead the OP this way.
  • · Replies 47 ·
10K
  • · Replies 30 ·
13K
  • · Replies 0 ·
  • · Replies 41 ·
11K
  • · Replies 20 ·
