Stuck in Evaluating an Indefinite Integral
The discussion revolves around evaluating the indefinite integral of the function involving e^(x^8). Participants suggest using the substitution u = x^8, leading to the derivative du/dx = 8x^7. A key point is that since x^7dx is present in the integral, it simplifies the process without needing to isolate dx. The correct approach is to express the integral as (1/8)∫e^u du, which participants work through collaboratively. The conversation emphasizes the importance of proper substitution techniques in integral calculus.
whatisphysics
Evaluate the indefinite integral.
I tried to use substitution.
I'm not so good with using the LaTex codes...so I attached a file I made in Word.
Thanks in advance!
Try using u = x^8
iamalexalright said:
Try using u = x^8
The x^8 from e^(x^8) or x^7?
I don't understand your question
But besides a poor choice of u in your original solution you don't carry out the integral properly
With my choice of u (u = x^8) compute du/dx and show me the new integral
Okay, I've now ended up with
\\frac{1}{7}\\int\\frac{e^u}{x^7} du
You should show me the steps you take to get there!
plus use the carrot to show superscripts with LaTeX: e^{u}
What is the derivative of u = x^8 with respect to x?
Can you show me how you would do it?
Alright, the integral is:
\int x^{7}e^{x^{8}}dx
I'll choose u = x^8
du = 8x^{7}dx
Here is where you had an issue before, notice that in the original integral I do have x^7dx in it ! This implies I don't need to divide by x^7, I just use the substitution:
\frac{1}{8}du = x^{7}dx
Can you finish it from here?
I'll choose u = x^8
du = 8x^{7}dx
Okay, I tried what you said. Can you check it, thanks! And how do I go on from there, I'm not very good at this, but I still want to learn!
\begin{aligned}<br /> dx &amp;= \frac{du}{8x^7} \\<br /> \int \frac{x^{7} \cdot e^u}{8x^{7}}dx &amp;= ...<br /> \end{aligned}
This is the 2nd time I saw someone work a u-substitution this way. Why isolate dx? I think it makes things complicated. Solve for 'an expression in the integral that contains dx' instead, like this:
\begin{aligned}<br /> u &amp;= x^8 \\<br /> du &amp;= 8x^7 dx \\<br /> \frac{1}{8} du &amp;= x^7 dx<br /> \end{aligned}
(because x7 dx appears in the integral)
So,
\int x^{7}e^{x^{8}}dx = \frac{1}{8}\int e^u du = ...
Thank you both so much!
And to eumyang, I don't understand, I thought it would be easier to isolate the dx, because you can simply just substitute the dx, isn't that right?
Anyway, thanks again!
