Proving N(H) is a Subgroup of G Containing H
  • MHB
  • Thread starter Jen917
  • Tags
    Subgroup
In summary, the conversation discusses defining N(H) as the set of elements in G such that the conjugate of H by x is still in H for all h in H. It is then shown that N(H) is a subgroup of G which contains H by proving closure and inverse properties. The conversation also raises questions about the finite nature of H and the bijectivity of the function.
Jen917
Let G be a group and let H be a subgroup.
Define N(H)={x∈G|xhx-1 ∈H for all h∈H}. Show that N(H) is a subgroup of G which contains H.
To be a subgroup I know N(H) must close over the operations and the inverse, but I am not sure hot to show that in this case.
Hi Jen917! Welcome to MHB! (Smile)
To prove that the operation is closed, we need to prove that for all $x, y \in N(H)$:
$$\forall h \in H: (xy)h(xy)^{-1} \overset ?\in H$$
Can we find that using $xhx^{-1} \in H$ and $yhy^{-1} \in H$? (Wondering)To prove that the inverse belongs to the set, we need a sub step first.
Either way, it requires that $H$ is finite. Is it?
Suppose $x$ is an element of $N(H)$.
Now consider the function $H\to H$ given by $h \mapsto xhx^{-1}$.
Is it a bijection? (Wondering)
1. What is a subgroup?
A subgroup is a subset of a larger group that satisfies the same group properties as the larger group. In other words, it is a smaller group within a larger group.
2. What is the significance of proving N(H) is a subgroup of G containing H?
Proving N(H) is a subgroup of G containing H is important because it shows that the normalizer of a subgroup H is itself a subgroup of the larger group G. This allows for further analysis and understanding of the relationship between H and G.
3. How do you prove that N(H) is a subgroup of G containing H?
To prove that N(H) is a subgroup of G containing H, you must show that it satisfies the three subgroup criteria: closure, associativity, and identity and inverse elements. This can be done by demonstrating that the elements of N(H) satisfy these properties when combined with the elements of H.
4. What is the role of the normalizer in subgroup analysis?
The normalizer plays a crucial role in subgroup analysis as it helps identify subgroups that are invariant under conjugation by elements of the larger group. It also helps in understanding the structure and properties of a subgroup within a larger group.
5. Can N(H) be a proper subgroup of G?
Yes, N(H) can be a proper subgroup of G. This means that the elements of N(H) are a subset of the elements of G, but not all of them. This is possible if there are elements in G that do not normalize H.
  • Linear and Abstract Algebra
