Subthreshold slope and transconductance
  • Thread starter Thread starter ZeroFunGame
    Slope
The discussion clarifies the distinction between subthreshold slope and transconductance in MOSFETs. The subthreshold slope is defined as the change in drain current divided by the change in gate voltage, while transconductance is proportional to the drain current divided by the difference between gate-source voltage (VGS) and threshold voltage (Vth). It is established that the subthreshold slope is relevant for gate voltages below Vth, where the drain current is small but not zero, whereas transconductance applies above Vth during normal operating conditions.
  • Understanding of MOSFET operation and characteristics
  • Familiarity with concepts of gate voltage, drain current, and threshold voltage (Vth)
  • Knowledge of exponential and logarithmic functions in electronics
  • Basic principles of semiconductor physics
  • Study the mathematical derivation of subthreshold slope in MOSFETs
  • Learn about the impact of temperature on transconductance
  • Explore the relationship between subthreshold slope and device scaling
  • Investigate the applications of transconductance in amplifier design
Electrical engineers, semiconductor physicists, and students studying MOSFET characteristics and their applications in circuit design.
ZeroFunGame
TL;DR
I'm trying to understand the difference between subthreshold slope and transconductance. The subthreshold slope is the change in drain current / change in gate voltage. The transconductance of a MOSFET is proportional to the drain current / VGS - Vth. It would seem the subthreshold slope is proportional to the transconductance? I'm trying to understand the physical significance and distinctions between subthreshold slope and transconductance. Thank you for any thoughts
As far as I can ascertain (regarding myself as a vacuum tube engineer!), the MOSFET has a gate voltage corresponding to cut-off, where the drain current is nominally zero. Above this gate voltage the drain current increase exponentially - it is like a square law device. The transconductance is the slope when biased above cut off and in normal operarting conditions.
For gate voltages below cut off, the drain current is not actually zero but is small. As bias is reduced further, the current reduces rapidly and if plotted as a log it is a straight line. This is similar to a diode. The slope of this line is the sub threshold slope.
Ah, so transconductance is always the relation above Vth for a MOSFET!
increases quadratically?
