rajeshmarndi
- 319
I want to have a formula of this kind,
(8+7+...+1) + (7+6+..+1) + (6+5+..+1) + ...1
I know , n+(n-1)+...+1 = n(n+1)/2
An Addition Series is a mathematical sequence in which each term is obtained by adding a constant number to the previous term.
The Sum of Successive Terms in an Addition Series is the total value obtained by adding all the terms in the series together.
To find the Sum of Successive Terms in an Addition Series, you simply add all the terms together. This can be done manually or by using a formula, depending on the complexity of the series.
The Sum of Successive Terms in an Addition Series is important in determining the overall trend and behavior of the series. It can also be used to make predictions and analyze patterns in the data.
Yes, the Sum of Successive Terms in an Addition Series can be negative if the series contains negative terms. In this case, the sum would be a negative number.
