Suitable op-amps/ parameters for subtractor circuits
For analog voltage subtractor circuits, general-purpose op-amps like the uA741 can be used if high accuracy is not required, while the LM358 is suitable for single-supply applications. Key parameters to consider include slew rate, maximum output voltage, and input voltage offset, as these affect the circuit's performance and dynamic range. A 1-mV input voltage offset in individual op-amps can lead to a combined offset of ±1.4 mV, impacting accuracy. For 10-bit equivalent accuracy, the subtracted signal amplitude should be at least 1.4 volts, limiting the useful dynamic range. Selecting the right op-amp is crucial for achieving the desired performance in subtractor circuits.
oldfoggy
Hi all,
I would like to know which op-amps are more suitable for an analog voltage subtractor circuit? Are there any parameters of the op-amp that I should take special note of, which has a more crucial effect on the subtractor circuit?
Thanks for your help in advance!
You can use any general purpose Op Amp such as uA741 as long as you don't need very high level of accuracy.
Take care you need +12 & -12 Volt dual supply for OpAmp.
Or you can use LM358 dual Opamp whis works with single 5 to 15 Volt DC supply.
Well there are things like the slew rate and maximum output voltage to take into consideration. It all depends on how much voltage you want at the output as well as what frequency you will be driving it at.
You should also review the input voltage offset and other similar offset parameters, because they will limit the analog dynamic range. If individual op-amps have an uncorrected 1-mV input voltage offset, then the quadrature input offset for two op-amps is ±1.4 mV. If you need 10 bit equivalent accuracy, then your subtracted signal amplitude should be at least 1.4 volts. So if the maximum linear output range is ±10 volts, your useful dynamic range is only about 10/1.4 = 7:1.
Bob S
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 29 ·
