Proving Sum of Combinations: nCr=2^n
  • Thread starter Thread starter amcavoy
    Combinations Sum
The discussion centers on proving the identity ∑_{k=0}^{n} (n choose k) = 2^n, which represents the total number of subsets of a set of size n. Participants reference Pascal's Triangle and the binomial theorem to illustrate that the sum of combinations corresponds to the number of ways to choose any number of objects from n. Several methods of proof are suggested, including combinatorial reasoning, induction, and the binomial expansion of (x+y)^n evaluated at x=y=1. While some express a desire for a symbolic proof, others note that geometric or combinatorial arguments can be equally valid. The conversation emphasizes the importance of clarity in understanding why the identity holds true.
amcavoy
I was just wondering how you would prove the following:
\sum_{k=0}^{n}\frac{n!}{k!\left(n-k\right)!}=2^{n}
Any help is appreciated.
Its easy to see once you know where to look. Look at pascals triangle. What is the value of the sum of all the numbers in each row equal to? Perhaps 2^n...where n is the row...
Now what does that binomial theorem have to say about combinations and pascals triangle again?
Do you see where to go from here?
Just so you know, what I am talking about is how you can show that your equation is believable but to prove it you would have to show all the details...
I see what you are saying about Pascal's Triangle. However, I would like to know if there is a way to prove this symbolically, rather than just seeing that it works. Does anyone have any suggestions?
Thanks a lot for your help.
combinatorially \binom{n}{k} which is the summand is the number of ways of choosing k objects (order unimportant) from n or the number of subsets fo size k of n objects.
you are adding these up from 0 to n.
so you are finding the total number of subsets of a set of size n. this is obvisouly 2^n
it may also be proved by induction or by noting it is the binomial expansion of (x+y)^n for x=y=1
If what you're asking is for a way to prove the identity directly...good luck.
The first time I realized that sum was equal to 2^n I went to trying to prove the identity like what you're asking. I never could...
But good luck to you.
As a side note, proving it the way matt grime said is just as good as any other way. After all, can you prove sin^2(x) + cos^2(x) = 1 symbolically? You could...perhaps...but it's no better than a geometric argument. And I think the geometric proof is more useful in the sense that you have a geometric understanding of why the identity is true.
Regards,
hopefully i gave a solution that is more explanatory than "jsut look at pascal's triangle" ie it explains why the rows add up to 2^n rather than just saying they do.
Yes of course. Thanks a lot for your help everyone.
You can also see that the sum is just equal to (1+x)^n evaluated at x=1
but i said that one too in one of the three proofs i gave...
Yes, but to the casual observer such things may not be so clear...thus, it never hurts to be explicit from time to time. :smile:
you are adding these up from 0 to n...
...to find the number of ways of selecting any number of objects out of n given objects. (ie: you can pick 0 objects or 1 object or 2 objects or...or all n objects).
Alternatively, you can think of this as assigning to each of the n objects, one of 2 labels, namely "chosen" and "not chosen". The total number of ways of assigning labels is hence 2^n, and this is exactly the process of choosing any number of objects.
You can prove Sum(nCk,k=0,1..n)=2^n as a straight summation problem by induction on n. It works for n=0 then assume it is true for n-1. Since 2^(n-1)+2^(n-1) = 2^n expand out the summations and rearrange terms and show (n-1)C(k-1)+(n-1)Ck=nCk Where nCk=n!/k!/(n-k)! and note that nC0=(n-1)C0=nCn=(n-1)C(n-1)=1.
