What is the general form and convergence of (k+1)r^k?
  • Thread starter Thread starter Caspian
    Sum
The discussion centers on the convergence and general form of the series ∑(k+1)r^k. A participant confirms that the series converges for |r| < 1 and derives the formula S(r) = 1/(1-r)², which applies to the specific case where r = 5/6, yielding a sum of 36. The conversation highlights the relationship between this series and the geometric series, emphasizing that it can be evaluated using derivatives. Participants express satisfaction with the clarity and utility of the derived formula for future calculations. The thread concludes with an appreciation for the insights gained regarding infinite series.
Caspian
[solved] Sum of k x^k?
I happened upon a thread in a math forum, where someone asserted that this is true:
\sum_{k=0}^\infty (k+1) \left(\frac{5}{6}\right)^k = 36
I suppose this makes intuitive sense. But if it's true, it must have a general form. I.e.,
\sum_{k=0}^\infty (k+1) r^k = ?
Now, I know that the geometric series converges like so:
\sum_{k=0}^\infty r^k = \frac{1}{1-r}
But by multiplying by (k+1) inside the summation completely changes things. Is there a name for this series? Is it true that it converges? If so, what does it converge to?
This question won't stop plaguing me. Since I don't know what this series is called, I'm having a hard time searching for it on the Internet.
Thanks!
Mathematics news on Phys.org
Well, I won't derive the general case for you but I will show you how to evaluate this particular sum (although, I'm not sure that I agree with the answer that someone else provided) . . .
S = \sum_{k=1}^{\infty}\frac{k5^k}{6^k} = \frac{5}{6} + 2\left(\frac{5^2}{6^2}\right) + \dots = \frac{5}{6} \left [ 1 + 2\left(\frac{5}{6}\right) + 3\left(\frac{5^2}{6^2}\right) + \dots \right ]
Therefore, we know that
S = \frac{5}{6} \left [ 1 + 2\left(\frac{5}{6}\right) + 3\left(\frac{5^2}{6^2}\right) + \dots \right ] = \frac{5}{6} \left ( 1 + \sum_{k=1}^{\infty}\frac{(k + 1)5^k}{6^k} \right )
With some simple manipulations, we can put this last sum into a more desirable form
\sum_{k=1}^{\infty}\frac{(k + 1)5^k}{6^k} = \sum_{k=1}^{\infty}\frac{k5^k}{6^k} + \sum_{k=1}^{\infty}\left(\frac{5}{6}\right)^k = S + \sum_{k=1}^{\infty}\left(\frac{5}{6}\right)^k
Now, using this expression we find that
S = \frac{5}{6} + \frac{5S}{6} + \frac{5}{6}\sum_{k=1}^{\infty}\left(\frac{5}{6}\right)^k
From which it follows that
S = 5 + 5\sum_{k=1}^{\infty}\left(\frac{5}{6}\right)^k
Using the formula for the sum of a geometric series, we can evaulate the last sum and find the value of S
S = 5 + 5\left(\frac{1}{1 - \frac{5}{6}}\right) = 5 + 5(6) = 35
Edit: Aside from any significant mistakes I may have made in evaluating that particular sum, you should also note that I evaluated the sum using very informal methods.
Convergence issues aside (actually it converges for every complex r with absolute value less than 1, and converges uniformly on every disk with a radius less than 1)
A good insight is that it is a derivative of a more simple series:
\frac{d}{dr}\sum^{\infty}_{k=0}r^{k+1}=\sum^{\infty}_{k=0}(k+1)r^{k}
And you know that:
\sum^{\infty}_{k=0}r^{k+1}=r\sum^{\infty}_{k=0}r^{k}=\frac{r}{1-r} (For any r for which it converges)
And therefore your sum is given by
S(r)=\frac{d}{dr}(\frac{r}{1-r})=\frac{(1-r)+r}{(1-r)^{2}}=\frac{1}{(1-r)^{2}}
Which also fits your special case r=5/6.
Wow, that's much simpler. It really makes me wish that I was more proficient with infinite series.
That was just what I was looking for -- not only the solution, but a tool to use in the future :).
Thank you so much!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
