Sum of n elements of a finite set of integers, 1 through s
The discussion focuses on calculating the probability of rolling a total t with n s-sided dice, specifically how to determine the number of combinations that yield this sum. The challenge arises in the range where n+s ≤ t ≤ (n-1)s, as traditional combinatorial methods become ineffective. Participants explore the convergence of the sum of rolls to a normal distribution, referencing the weak law of large numbers. They seek clarification on the parameters σ and μ in the context of the normal distribution related to n, s, and t. The conversation highlights the complexity of the problem and the need for an efficient solution.
Nessalc
The general problem I'm trying to solve is the probability of rolling a total t on n s-sided dice. A good chunk of the problem is easy enough, but where I run into difficulty is this:
How many combinations of dice will yield a sum total of t? Because the number set is limited, {a \choose n-1} (where a={n(s+1) \over 2} - \left|{n(s+1) \over 2} - t\right|) no longer works when n+s \leq t \leq (n-1)s. It is this region in the middle that interests me. Enumerating all combinations could be time-consuming, and, I expect, is entirely unnecessary. Is there a known formula for computing these numbers?
sum of the m rolls diverges as m gets large. but we can use standardize to make it converge to standard normal distribution. this the weak law of large number says.
I'm not sure I understand what you're saying. The total t must be in the range [n, ns]. I am aware of the idea that it would probably converge to a normal distribution, but for {1 \over {\sqrt{2\pi\sigma^2}}} e^{-{{\left((x-{n(s+1) \over 2})-\mu\right)^2} \over {2\sigma^2}}}, what would \sigma and \mu be in terms of n, s and t?
That's exactly what I was looking for, thanks!
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
