Sum of Products of N Natural Numbers
  • MHB
  • Thread starter mathworker
  • Tags
    Sum
In summary, the conversation discusses finding the general formula for the sum of products of an n-tuple containing consecutive natural numbers, not necessarily starting with 1. The formula is proved by induction, using the fact that to get from S_n to S_n+1, the terms (n+1)(1+2+...+(n+1)) need to be added. The formula is shown to be Sn = (n(n+1)(n+2)(3n+1))/24.
mathworker
111
If we are given with set of n natural numbers and asked to find the sum of all possible products of two number..
E.G:
{1,2,3} is given then ,
1*1+1*2+1*3+2*2+2*3+3*3=s
how to find the general formula of SUM for given n-tuple containing consecutive natural numbers not necessarily starts with 1 or at least first N natural numbers
Re: sum of products of N
i tried with following approach ,
S=\(\displaystyle \sum n^2 + \sum n(n-1)...\sum n(n-(n-1))\)...
and tried finding sum by splitting terms but it gone wrong 'cause there are some negative terms which are meant to be ignored(Lipssealed)
You should be able to check that the formula for $S_n$ is $S_n = \frac1{24}n(n+1)(n+2)(3n+1)$. Prove this by induction, noting that to get from $S_n$ to $S_{n+1}$ you need to add the terms $(n+1)(1+2+\ldots+(n+1)).$
yeah i got from Opalgs idea,
\(\displaystyle Sn - S(n-1)=n(n(n+1))/2\)
\(\displaystyle S(n-1)-S(n-2)=(n-1)(n-1)n/2\)
and by canceling up to \(\displaystyle S_0\)
\(\displaystyle Sn = \sum n^2(n+1)/2\)
\(\displaystyle =n(n+1)(n+2)(3n+1)/24\)
thanks oplag...:D
The general formula for the sum of products of n natural numbers can be written as follows:
S = (n-1)*(n-2)/2 + (n-1)*(n-2)*(n-3)/6 + ... + (n-1)*(n-2)*(n-3)*...*2*1
This formula can be derived by considering the pattern in the given example. For a set of n natural numbers, the first term in the sum will be the product of the first two numbers, the second term will be the product of the first three numbers, and so on. This pattern can be continued until the last term, which will be the product of all n numbers.
To find the general formula, we can use the concept of combinations. The first term in the sum represents the number of ways we can choose 2 numbers from a set of n numbers. The second term represents the number of ways we can choose 3 numbers from a set of n numbers, and so on. This can be written as nC2, nC3, ..., nCn. Therefore, the general formula can be written as:
S = nC2 + nC3 + ... + nCn
Using the formula for combinations, nCk = n! / (k!(n-k)!), we can simplify the above formula to:
S = n! * (1/2 + 1/6 + ... + 1/n!)
This formula can also be written as:
S = n! * (1/2! + 1/3! + ... + 1/n!)
Or, in a more compact form:
S = n! * ∑(1/k!)
Therefore, for any given n-tuple containing consecutive natural numbers, the sum of products of all possible pairs of numbers can be calculated using this general formula.
FAQ: Sum of Products of N Natural Numbers
1. What is the "Sum of Products of N Natural Numbers"?
The "Sum of Products of N Natural Numbers" is a mathematical concept that involves taking the product of consecutive natural numbers and then adding them together. It is often represented by the formula: 1*2 + 2*3 + 3*4 + ... + (N-1)*N.
2. How is the "Sum of Products of N Natural Numbers" calculated?
To calculate the "Sum of Products of N Natural Numbers", you can use the formula: (N*(N+1)*(N+2))/3. This formula can be derived by using the concept of arithmetic progression and the formula for the sum of an arithmetic series.
3. What is the significance of the "Sum of Products of N Natural Numbers" in mathematics?
The "Sum of Products of N Natural Numbers" has significance in various fields of mathematics, such as number theory, combinatorics, and algebra. It is also used in solving problems related to permutations and combinations, as well as in the proof of certain mathematical theorems.
4. Can the "Sum of Products of N Natural Numbers" be extended to include non-consecutive natural numbers?
Yes, the concept of "Sum of Products of N Natural Numbers" can be extended to include non-consecutive natural numbers. This is known as the generalized sum of products, and it involves taking the product of any set of natural numbers and then adding them together.
5. Are there any real-life applications of the "Sum of Products of N Natural Numbers"?
Yes, the "Sum of Products of N Natural Numbers" has practical applications in various fields, such as computer science, engineering, and economics. It can be used to calculate the total cost of a project, the total number of possible combinations in a set, and the total number of ways to arrange a set of objects.
