Super capacitor for running DC motor
This discussion focuses on using a Maxwell super capacitor to power a DC motor with specifications of 90V - 120V DC and 15A current for a minimum of 10 seconds. The user calculated a discharge time of 11.6 seconds using the formula t=[C*(V0-V1)/I], confirming the suitability of the chosen super capacitor with a capacitance of 5.8F. Additionally, the user plans to charge the capacitor using a 110V AC supply with a transformer and rectifier. Recommendations include using a reverse biased Schottky diode to protect the motor from inductive kickback.
  • Understanding of super capacitor specifications and applications
  • Knowledge of DC motor operation and requirements
  • Familiarity with electrical formulas for capacitance and discharge time
  • Basic knowledge of AC to DC conversion using transformers and rectifiers
  • Research the specifications and alternatives for Maxwell super capacitors
  • Learn about the implementation of Schottky diodes in motor circuits
  • Explore methods for charging super capacitors safely from AC sources
  • Investigate the effects of inductive kickback and protection strategies in DC motor applications
Electrical engineers, hobbyists working on motor control projects, and anyone interested in energy storage solutions using super capacitors.
Yasir
Hi,
I am planning to run a DC motor using a super capacitor. The specification of the motor are:
  • Voltage : 90V - 120 V DC
  • Current : 15 A
  • Duration : Should run for atleast 10 seconds.
I have finalized this super capacitor from maxwell for the above operation http://www.maxwell.com/products/ultracapacitors/docs/160vmodule_ds_3000246-5.pdf
I have planned to charge this capacitor to 120V and then discharge till 90V DC.
I have used the formula:
t=[C*(V0-V1)/I] where,
t = Discharge time (sec)
C = Capacitance (F)
V0 = Initial Voltage (V)
V1 = Final Voltage (V)
I = Current (A)
Thus applying the values to the formula:
t ={5.8(120-90)/15} (120 - 90 is the voltage range for the motor, 15 is req. current)
={5.8(30)/15} (5.8 F is the capacitance of the Super cap mentioned in datasheet)
=11.6 sec.
11.6 sec which is more than what i require.
I got the above formula from Elna Supercapacitor, Illinois Capacitor Inc and Maxwell (Page 2) http://www.maxwell.com/products/ultracapacitors/docs/applicationnote_maxwelltestprocedures.pdf so m pretty sure about the formula.
So guys please help me here and let me know whether the calculations and the product i have finalized for running the motor for 10 seconds (atleast) is suitable or not. What problems i may face during this experiment. I have planned to use AC 110V supply with transformer/rectifier to charge the capacitor to 120 V. Do i need to add any other equipment between motor and supercap or a direct connection is sufficient.
Thanks in advance. :)
C = Q / V
Q = I * t
∴ t = V * C / I
and so: dt = dv * C / I
Your 11.6 sec is correct.
To charge the capacitor to 120V DC you will need to rectify 120V / Sqr(2) = 85V AC
To protect the motor insulation, you might consider a reverse biased Schottky diode across the motor to catch any inductive kick produced during switching.
Thanks for the reply Baluncore...
Guys all kind of suggestions are welcome...anything you want to add any modifications or any other super cap product cheaper and smaller than what i have suggested in the first post ...even if you think whatever i have posted is right, please let me know...
Thanks a lot again..
  • · Replies 18 ·
12K
9K
  • · Replies 68 ·
16K
