Superconductivity for light beams?
The discussion centers around the concept of superconductivity and its potential application to light beams, specifically whether there exists a material that allows light to propagate without any losses. Participants explore the differences between electrical current and light propagation, as well as the implications of superconductivity in this context.
  • Some participants question the feasibility of superconductivity for light, suggesting that light behaves differently from electrical current.
  • One participant proposes that the question could be reframed to inquire about "lossless mediums" for light propagation, citing optical fibers as a low-loss option, though not entirely lossless.
  • Another participant emphasizes the need for clarity in terminology, suggesting that "lossless medium" is a more appropriate phrase than "superconductivity" when discussing light propagation.
  • Concerns are raised about the differences in propagation mechanisms between electric current (conduction) and light (radiation), with some arguing that discussing superconductivity in relation to light is meaningless.
  • Participants express confusion about the similarities and differences between electrical current and light, particularly regarding their propagation speeds and the role of electromagnetic fields.
Participants do not reach a consensus on the applicability of superconductivity to light propagation. There are competing views on the nature of light and electrical current, as well as the terminology used to describe loss in materials.
Some participants highlight the need for a clearer understanding of the underlying principles of light and electrical current, as well as the limitations of current materials in achieving lossless propagation of light.
Tspirit
As is well known, superconductivity is described as a property of zero-resistance for electrical current, however, I want to know, is there any material with superconductivity for light beams, in which the light beams can propagate with no losses?
Science news on Phys.org
do you understand what an electric current is and how it propagates in a conductor ?
do you understand what light is and how it propagates ?
when you answer those and understand the difference, you will discover a flaw in your idea/thought :wink:Dave
I think, it can be re-framed as "Do we know about any substance through which light can travel through without any attenuation?"
To which a good enough answer would be optical fiber. The point is light, being light, can die down as it progresses through a media, where as the current we think of as a flow of charge doesn't "die down" in a typical closed circuit. However, resistor can be treated as a dissipating agent just as easily as the opacity of a material for light.
Ranvir said:
I hope you are asking this question in a literal sense and not in a derogatory manner. I
please keep your derogatory comments to yourself !
I am trying to see what understanding the OP has on the topic without giving direct answers
We here at PF try to get people to think for themselves, it aides in the learning process :smile:
Point taken, that makes sense, the more I think about it.
the problem is, we have no idea what the OP is thinking. So we need to get them to tell us their understanding and also to
more specifically define what they are wanting to know , which at the moment, from their opening post, is a little vague :smile:
Lets see how they respondDave
Thank Dave and Ranvir for kind replies. Ranvir tells what I want to know. I am searching for a kind of material that won't introduce losses when the light propagates in, whatever the principle is. I have considered the optical fiber, but the losses will increase with the distance increasing. Thought of superconductivity, I asked the question. So, is there any solution, even in theory?
nothing that I am aware of ... all mediums that will support the transmission of light will have losses
again I ask, since you didn't answer my questions ...
do you understand what light is and how it is different to an electric current ?
Dave
As I know, light is essentially a kind of electro-magnetic wave, it can propagates in vacuum with a speed of ##c##. It propagates in a medium with a speed of ##c/n##, ""n"" is the refractive index of medium.
While electric current is a field formed by the moving of electrons, it also propagates with ##c##, the difference to light is that it need a medium to propagate in. The moving of electrons will stopped or blocked by something called resistance and the corresponding current will decrease. At a very low temperature, some materials can have a property of zero resistance, which is called superconductivity.
Tspirit said:
While electric current is a field formed by the moving of electrons, it also propagates with ccc, the difference to light is that it need a medium to propagate in.
this bit needs revised a bit :smile:
The electric field exists regardless of it the electron ( charge carrier) is moving or not.
That is, a single motionless charged particle electron/proton already has an electric field around it
http://www.physicsclassroom.com/class/circuits/Lesson-1/Electric-Field-and-the-Movement-of-Charge
electrons don't move at the speed of light they actually move at a slow speed in a conductor ~ 1mm / sec give or take a bit depending of a few variables --- google electron drift
The electric field propagates at less than the speed of light in anything other than a vacuum, how much less depends on the conductor, insulation type etc
The electric filed will also happily propagate in a vacuum ... It does not need a medium. Same for the magnetic field
what I am aiming towards with these Q's and comments to you is that there is a very different process between the movement/propagation of an electric charge ... CONDUCTION and the movement/propagation of light ( an electromagnetic field) ... RADIATION
Light doesn't conduct ( well I have never seen it written anywhere that it does), therefore talking about superconductivity for light is meaninglessDave
The words you use are at fault here.
What you want is a "lossless medium" for light propagation (presumably over a range of frequencies). You should use that phrase rather than invoking "superconductivity", because "superconductivity" involves a number of consequences and effects, NOT just "zero resistance".
Zz.
But only or DC; the losses in a superconductors increase as you increase the frequency. In fact, at frequencies above a few hundred GHz (which is taking you close to the far infrared; i.e. "light") the losses in superconductors can exceed those of normal metals at the same temperature.
This is not true. Optical fiber may be low loss, but most certainly is not zero loss. Just look at the need for optical repeaters in fiberoptic trans-Atlantic communication cables on the ocean floor...
https://en.wikipedia.org/wiki/Submarine_communications_cable
Thank you for your detail interpretation. However, I am still a little confused. Both electrical current and light radiation, are propagating with the help of motion of electro-magnetic field and their speeds are both near the light speed. So in the concept of "field", what's the essential difference between them? Are they interpreted by classical Maxwell electro-magnetic equation?
but the electric current ISNT moving at the speed of light !
did you do as I suggested and google electron drift ?
Yes, I have followed your suggestion and I know that the velocity of electron drift is very slow. But the foundation of electrical field is very fast (nearly the speed of light), in other words, the transmission speed of information carried by electrical field is very fast. See https://en.wikipedia.org/wiki/Speed_of_electricity. So my point is why the electrical field of electrical current can't be seen as the light current, since they are both electromagnetic field in nature?
Thanks, I will follow up on this
because conductivity ( superconductivity) deals with current, the movement of charge carriers, NOT electric or EM fields
there is no such thing as "light current"
Thank you for your kind help. I seem to get the point: superconductivity is a behavior of charge carriers and happens when the resistance of their moving is zero. The propagation of light don't need the help of the moving of something, so there is no corresponding resistance and thus superconductivity.
I'm a bit surprised to not see the obvious answer here: the most lossless medium for current and radiation is ... space.
Do you mean "space" or "vacuum"? "Space" isn't a medium. A volume of space may contain a medium, or more than one medium.
Zz.
Actually, Dave already mentioned it...
davenn said:
The electric field will also happily propagate in a vacuum
but the OP seemed to be asking about propagation around a path with no loss, which might be true at the Universe's scale, but not on a planetary scale... :smile:
For electrical current, it can't propagate in space because it need moving of charge carriers such as electrons. For light radiation, it can. However, it can't turn the corner and hence can't realize free transmission of information with arbitrary directions.
you may be interested to learn that the path of light/and RF EM waves can be bent / refracted
large gravitational fields will bend the light path of stars and galaxies etc
the general name for this is called gravitational lensing
EM waves of any frequency can be refracted when passing between different mediums
Not sure I follow. A stream of electrons exactly constitutes a current, why would this be disqualified?
I made a mistake. Yes, you are right. But what I want is controllable current which can transmit information, just like telephone or fiber optics. I have no idea if a stream of electrons in vacuum can do this.
They can, over a short range.
You can always turn the floodgates on and off on a dam and monitor water levels downstream.
rumborak said:
I'm a bit surprised to not see the obvious answer here: the most lossless medium for current and radiation is ... space vacuum.
Fixed it for you.
Zz.
As I recall, someone on this forum said that light doesn't require a medium. I argued, and put forth a "theory" of how vacuum was a medium. My post was deleted by an "official" of this forum.
Something no one mentioned is that non-focused light dissipates as the square of the distance, even if there is no loss from the medium.
  • · Replies 16 ·
  • · Replies 24 ·
  • · Replies 22 ·
