Undergrad Superconductor momentum conservation
The discussion centers on the behavior of superconductors in relation to momentum and energy conservation. It explores whether electrons in a superconducting loop transfer momentum and energy to the metal lattice when they accelerate around corners. The consensus is that while momentum is conserved, energy does not dissipate once equilibrium is reached. Additionally, the current density of the superconducting wire is highlighted as a limiting factor, where exceeding this density could introduce resistance. Overall, the conversation emphasizes the intricate balance between current density, external magnetic fields, and temperature in maintaining superconductivity.
Danyon
I often hear that a superconductor can hold a current indefinitely, I have a thought experiment which relates to this claim. Consider a closed square loop of superconducting wire, this wire carries some current. Will the electrons in the circuit transfer momentum and energy to the metal lattice when the electrons accelerate around the corners of the square circuit? If yes, then the current will actually slowly dissipate, if no then you could accelerate the electrons in the wire, giving a recoil force, and the electrons would travel all around the wire without transferring momentum where they can be accelerated again. This would be a momentum conservation violating thruster...So is current or momentum conserved?
Momentum yes, energy no (at least not once the coil reached an equilibrium position).
Momentum is conserved, you get should a tiny bit of tension in the wires balancing the momentum transfer of the cooper pairs.
Does that mean the only limitation then will be current density of wire which has become supper conductor. I mean if current is less than its current density then it will feel no resistance and if current is more than its current density then some kind of resistance (friction) will come in practice?
Here I refer to current density as a relative term which depends upon frequency of operation due to skin effect and proximity effect.
Current density, external magnetic field and temperature form a region of superconductivity in the "corner" of low values for those three parameters.
A relative asked me about the following article: Experimental observation of a time rondeau crystal https://www.nature.com/articles/s41567-025-03028-y I pointed my relative to following article: Scientists Discovered a Time Crystal That Reveals a New Way to Order Time https://www.yahoo.com/news/articles/scientists-discovered-time-crystal-reveals-180055389.html This area is outside of my regular experience. I'm interested in radiation effects in polycrystalline material, i.e., grain...
  • · Replies 61 ·
  • · Replies 38 ·
  • · Replies 17 ·
  • · Replies 16 ·
