Superposition for dependent sources and Pspice
- Thread starter DODGEVIPER13
- Start date
- Tags
- Pspice Sources Superposition
76 replies · 7K views
DODGEVIPER13
- 668
- 0
Ah ok thanks
Mentor
- 20,989
- 2,934
DODGEVIPER13 said:Ok man well if you are not tired I have this problem https://www.physicsforums.com/showthread.php?t=676267 posted in calculus it was suppose to be in engineering but I posted it wrong it has my work for 2
I don't follow the work that you posted there; there are no comments accompanying the equations to explain what you are attempting to do in each step. It would help if you could elucidate your attempt.
DODGEVIPER13
- 668
- 0
Ok so don't follow the (1) at the top, it starts at (2). From the first equation with the 3A source removed -8+3ix'+3ix'+2ix'=0 I solve for ix'=1A. Then I remove the 8v source and get ( v''/3)+((v''-2ix'')/3)=4 and relate the dependent source to v'' with v''=-2ix'' solve for ix'' which I find to be -2A and then plug into my formula for Ix=Ix'+Ix'' and I get 1+-2=-1A
Mentor
- 20,989
- 2,934
OkayDODGEVIPER13 said:Ok so don't follow the (1) at the top, it starts at (2). From the first equation with the 3A [4 amp source] source removed -8+3ix'+3ix'+2ix'=0 I solve for ix'=1A.
Why would you write v''=-2ix'' ? One is a node voltage and the other a dependent supply voltage, and they are separated by a resistor.
What you want is to replace v'' with some function of Ix''. How is Ix'' related to v'' ?
DODGEVIPER13
- 668
- 0
Uh I have no idea that how the book did it I assumed sice they were in parallel or something
DODGEVIPER13
- 668
- 0
Hmm I was thinking could it be v''/3=-2Ix so that when I sole I get Ix'' to be -(6/7) which when added to 1 A I get (1/7) for Ix
Mentor
- 20,989
- 2,934
DODGEVIPER13 said:Hmm I was thinking could it be v''/3=-2Ix so that when I sole I get Ix'' to be -(6/7) which when added to 1 A I get (1/7) for Ix
Nope. Look at the diagram and where Ix is. How is it related to the node voltage? It has nothing (directly) to do with the dependent source. How would you write Ix if you were performing nodal analysis?
DODGEVIPER13
- 668
- 0
Ok so 3Ix+4=I1
DODGEVIPER13
- 668
- 0
Oh wait could it be 3ix+4+2ix(1)=0
DODGEVIPER13
- 668
- 0
-8+3 Ix=0
DODGEVIPER13
- 668
- 0
Oh yah good point so could it be v''=-3Ix
DODGEVIPER13
- 668
- 0
Heh good because I solved it out and found Ix''=-1.5 and Ix=-.5A
Help with PSpice/OrCAD Voltage Dependent Sources
- JerrySinField
- · Replies 1 ·
- Engineering and Comp Sci Homework Help
- Replies
- 1
Nodal Voltage Analysis with dependent sources
- sparkie
- · Replies 4 ·
- Replies
- 4
Superposition with a dependent current source
- DODGEVIPER13
- · Replies 5 ·
- Replies
- 5
Understanding dependent sources in electric circuits
- zenterix
- · Replies 19 ·
- Electrical Engineering
- Replies
- 19
The superposition theorem with dependent sources
- DODGEVIPER13
- · Replies 9 ·
- Replies
- 9
Engineering Circuit Theory Question KCL and Dependent Sources?
- Jose F Gomez D
- · Replies 4 ·
- Replies
- 4
Engineering Finding Vy in a Circuit with Dependent Sources
- maximade
- · Replies 4 ·
- Replies
- 4
Engineering Elementary Linear Circuits - Dependent Sources
- Devtycoon
- · Replies 15 ·
- Replies
- 15
Supermesh analysis w/ dependent sources
- rms5643
- · Replies 9 ·
- Replies
- 9
Dependent source with 2 other sources (using superposition), mesh
- Color_of_Cyan
- · Replies 10 ·
- Replies
- 10
