Superposition of total electric field
The discussion revolves around the application of the principle of superposition to find the total electric field generated by two non-conducting cylinders, each of length L and radius a, separated by a distance d. The original poster is attempting to understand how to combine the electric fields from both cylinders at a point r from the first cylinder.
  • Participants discuss the principle of superposition, suggesting that the total electric field can be found by adding the fields from each cylinder in isolation. There are questions regarding the nature of the cylinders (conductors vs. non-conductors) and the assumptions about their lengths relative to the distance r. Some participants provide examples using infinite line charges to illustrate the concept.
The discussion is ongoing, with participants exploring different interpretations of the problem and providing insights into the application of Gauss's law. There is recognition of the need for additional information regarding the charge distribution and the assumptions being made. Some participants have offered guidance on how to approach the problem using the principle of superposition, while others are clarifying the conditions under which the fields are calculated.
Participants note that the cylinders are treated as infinite and that the point of interest for the electric field is never inside either cylinder. There is also a discussion about the implications of treating the cylinders as infinite and the potential effects of image charges if they were conducting.
aznmaverick
2 Cylinders each of length, L, are separated by a distance d. Each has a radius, a. Use the principle of superposition to find the total electric field at a distance, r, from the 1st cylinder.
What I know so far: For One cylinder
Applying gauss law, i have E(2([tex]\pi[/tex])(r)(L) = charge enclosed/ [tex]\epsilon[/tex]0
so solving for E, E = [tex]\sigma[/tex]a/[tex]\epsilon[/tex]0r
I'm not sure how to apply the principle of superposition for both fields combined. Any advice?
The principle of superposition just says that to find the field for both cylinders, just add the fields each one would have in isolation.
Your problem and diagram don't really have enough information--it would help to know whether the cylinders are conductors or have a charge density as a function of r? How much charge total? Also, we're supposed to assume L>>r?
Here's the problem I'll do to demonstrate the principle of superposition: two infinite parallel line charges with lambda charge per unit length, one at position r=0 and the other at r=d in the x direction.
Solving for the field around one line charge using Gauss's law,
[tex]\overrightarrow{E}=\frac{\lambda}{2\pi \epsilon _{0}} \frac{1}{r}\widehat{r}[/tex]
Now to do the superposition principle, let's superimpose some cartesian coordinates. Call the direction along the line charges the y direction, and let the direction from the left line charge to the right line charge be the x direction. We'll find the field as a function of x and z, since it is independent of y. The left line charge is our origin, i.e., [tex]\overrightarrow{r}(\textrm{left line charge})=\overrightarrow{0}[/tex] Therefore, the position of the right line charge is [tex]\overrightarrow{d}=d\widehat{x}[/tex]. Call the vector from the left line charge to our field point [tex]\overrightarrow{r}=x\widehat{x}+z\widehat{z}[/tex] and the vector from the right line charge to the field point [tex]\overrightarrow{{\mathfrak{r}}}[/tex].
So superposing these two fields,
[tex]\overrightarrow{E_{total}}=\overrightarrow{E_{L}}+\overrightarrow{E_{R}}=\frac{\lambda }{2\pi \epsilon _{0}}\frac{1}{||\overrightarrow{r}||}\widehat{r}+\frac{\lambda }{2\pi \epsilon _{0}}\frac{1}{||\overrightarrow{\mathfrak{r}}||}\widehat{{\mathfrak{r}}}=\frac{\lambda }{2\pi \epsilon _{0}} \left (\frac{\overrightarrow{r}}{x^{2}+z^{2}} +\frac{\overrightarrow{r}-\overrightarrow{d}}{(\left x-d \right )^{2}+z^{2}} \right )=\frac{\lambda }{2\pi \epsilon _{0}} \left (\frac{x\widehat{x}+z\widehat{z}}{x^{2}+z^{2}} +\frac{\left ( x-d \right )\widehat{x}+z\widehat{z}}{(\left x-d \right )^{2}+z^{2}} \right )[/tex]
Kind of a messy form but I'm sure you could massage it a bit.
Now the field outside a charged cylindrical is equal to that but zero inside the cylinder's radius, so you can easily make that correction for the problem.
Now if we superposition one line charge located at r=0 and another line charge at r=d
[[oops, I made a mistake here, let me rework this.]]
Yes, we assume that L>>a (the radius of the cylinders). The one on the left has a (+sigma) density charge and the one on the left has a (-sigma) density charge. Hope this information helps!
Oh well I did it in terms of charge per length instead of charge per area. You can easily swap out lambda. For a cylinder radius a,
[tex]\lambda =2\pi a\sigma[/tex]
Ok, so that would be the combined electric force at that point, r, away from the 1st cylinder?
Well the answer I gave you is for two infinite line charges. It tells you the field at a vector [tex]\overrightarrow{r}=x\widehat{x}+z\widehat{z}[/tex] away from the left line charge.
I don't know if you want to treat your finite cylinders as infinite. (Given only L>>a is not good enough, because maybe r>>L and the cylinders could look like point charges.) If you do, that will be the answer provided r is not inside one of the cylinders. If the point r is inside one of the cylinders, the contribution from the line charge associated with that cylinder would disappear.
Also, if your cylinders are conducting cylinders I think there may be some image charge effects that I'm not really sure of.
They are treated as infinite and the distance r is never inside the other cylinder. the distance of the cylinders apart from each other is d. And we want to find the total e-field at a point r (for r<d) The cylinders are non conducting cylinders well. Does this make more sense now?
Yes, it makes a lot more sense now.
Keeping in mind [tex]\overrightarrow{r}=x\widehat{x}+z\widehat{z}\Rightarrow r=\sqrt{x^2+z^2}[/tex]
For all points r<d,
[tex] \overrightarrow{E}(x,z)=\frac{a\sigma }{\epsilon _{0}}\left\{\begin{matrix}<br /> \frac{(x-d)\widehat{x}+z\widehat{z}}{(x-d)^{2}+z^{2}} & r<a\\ <br /> \frac{x\widehat{x}+z\widehat{z}}{x^{2}+z^{2}}+\frac{(x-d)\widehat{x}+z\widehat{z}}{(x-d)^{2}+z^{2}}& a<r<d\\ <br /> <br /> \end{matrix}\right.[/tex]
how did u get the answer[tex]\alpha\sigma[/tex]/[tex]\epsilon<sub>0</sub>[/tex]??
for a infinite line charge its just E= [tex]\lambda[/tex]/2[tex]\pi\epsilon<sub>0</sub>\alpha[/tex] for one of the cylinders rite? and then if we apply the superposition principle we get [tex]\alpha\sigma[/tex]/[tex]\epsilon<sub>0</sub>[/tex]??
Here's the equation:
[tex]\overrightarrow{E_{\textrm{single line charge}}}(\overrightarrow{r}) = \frac{\lambda}{2\pi \epsilon _{0}} \frac{1}{r}\widehat{r} =\frac{a\sigma }{\epsilon _{0}}\frac{1}{r}\widehat{r}[/tex]
You have one of each of those for the left and right line charge. The left and right line charges have two different r vectors, as I stated above, where I called them [tex]\overrightarrow{r}[/tex] and [tex]\overrightarrow{\mathfrak{r}}[/tex].
That's what lead to that big formula leading to those messy x and z expressions.
However, those big x and z expressions give the answer for two LINE charges. To change the answer to be for a cylinder and satisfying all the other conditions you listed, the contribution from the left line charge disappears for r<a.
ook, sounds good, thanks so much!
