Surface Area [Double Integral]
5 replies · 6K views
1d20
I’m doing a lot of double integrals to find surface area problems, and I don’t think I’m setting them up quite right. For example,
“Find the surface area of the portion of the sphere [itex]x^2 + y^2 + z^2 = 25[/itex] inside the cylinder [itex]x^2 + y^2 = 9[/itex].”
I converted the sphere to a function of z: [itex]\sqrt{25 - x^2 - y^2}[/itex]
Then I found the partial derivatives:
fx = [itex]\frac{-x} {\sqrt{25 - x^2 - y^2}}[/itex]
fy = [itex]\frac{-y} {\sqrt{25 - x^2 - y^2}}[/itex]
Then I set up the integral:
SA = [itex]\int \int \sqrt{1 + (fx)^2 + (fy)^2} dx dy[/itex]
SA = [itex]\int \int \sqrt{1 + \frac{x^2} {25 - x^2 - y^2} + \frac{y^2} {25 - x^2 - y^2}} dx dy[/itex]
Adding fractions, I get:
SA = [itex]\int \int \sqrt{ \frac{25} {25 - x^2 - y^2} } dx dy[/itex]
Converting to polar, I get:
SA = [itex]\int_0^3 \int_0^{2\pi} r\sqrt{ \frac{25} {25 - r^2} } d\theta dr[/itex]
(That pi should be a part of the integral range, but I can’t find the fraking index of forum code.)
I can't think of a way to integrate this, so I think I didn't set it up right.
Looks ok to me. You've got an extra r^2 in the numerator of the last expression, but I'll assume that's a typo since the expression before it looks good. So you want to integrate r/sqrt(25-r^2). Just use a u-substitution.
You mean a function of x and y and you would write [itex]z = f(x,y)=\sqrt{25 - x^2 - y^2}[/itex], which gives only the top half of the sphere.
SA = [itex]\int_0^3 \int_0^2pi r\sqrt{ \frac{r^2} {25 - r^2} } dO dr[/itex]
OK until that last step. Why did you replace the 25 by r2? And when you want more than a single letter in the limit use {} to enclose, like this:
[tex]\int_0^3 \int_0^{2\pi} r\sqrt{ \frac{25} {25 - r^2} } d\theta dr[/tex]
You can right click on that formula to see how I changed it in a couple of spots. Then don't forget, this is just the top half.
[Edit] Dang! Dick beat me to it again.
It's good you came in. I missed that extra factor of 2.
Thanks! It was r being in the denominator inside a radical that threw me off.
While I'm here, does this forum have a list of all the symbol codes? I'd post here more often if I didn't have to 'cheat' from other threads every time I want to post.
You can read my signature file for one way to get some of them. Or if you are using TeX, you can click on the [itex]\Sigma[/itex] icon above in the advanced edit box for a TeX editor.
And I just now noticed there are symbols to the right of the advanced edit box.
