Understanding Surface Tension of Liquids: Factors and Measurement Methods
The surface tension of a liquid, such as water, varies depending on the medium it interfaces with, being higher when in contact with air than with glass. Measuring surface tension using a glass capillary only reflects the interaction between water and glass, not water and air. Typically, surface tension is defined at the liquid-gas interface, as liquid-solid interactions complicate the measurement due to adhesive forces. In cases of weak adhesion, the liquid-solid interface can be considered part of the surface, while strong adhesion can lead to negative effective surface tension. The height of liquid in a capillary and the contact angle at the interface provide insights into both liquid-solid and liquid-air surface tensions.
pivoxa15
The surface tension of a liquid such as water depends on the medium in which it shares (or the substance that shares with the liquid's boundary)?
If that medium or substance is air than the surface tension measured would be higher than if it was glass.
Correct?
If you try to measure surface tension by only using the method of putting a (glass) capillary in a liquid such as water and see how far it rises, you will only calculate the surface tension of water to glass. It is not possible to calculate the surface tension of water to air this way?
To the best of my knowledge, a liquid surface (if not additionally specified) is defined as the liquid-gas interface. A liquid-solid interface does not typically fall under the classification of a surface, unless specifically stated.
The reason for including only the former type of interface is that the liquid-gas intermolecular interactions are typically negligible compared to the liquid-liquid intermolecular interactions, irrespective of the gas (whereas the liquid-solid interactions depend strongly on the nature of both substances). This large difference is what gives the surface different properties than the bulk. And the ability to approximate the liquid-gas interactions as non-existant, makes it relatively easy to calculate these properties.
With a liquid-sold interface, things become more tricky - there could be adhesive forces between the two. In the limit of very weak adhesion between a liquid and its neighboring solid (e.g., Hg and glass, but not mercury and brass nor water and glass), it becomes reasonable to include this interface also as a part of the liquid surface. In the limit of strong adhesive forces, the interface becomes the mathematical opposite of a surface, and can be treated as though the "surface tension" had a negative value there. This adhesion between some liquid-solid pairs (e.g., water and glass) is what leads to capillarity. And the height of the column is a function of the liquid-solid surface tension (as you indicated above). However, the angle of contact at the walls of the mesiscus is a function of both the liquid-solid as well as the liquid-air surface tensions (since the line of contact is the boundary between all three phases). So, by measuring the height and the angle of contact, we can know the value of both surface tensions.
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
