Surjective functions and partitions.
The discussion focuses on the properties of surjective functions and their relationship to partitions of a set. The size of the set A, which contains all functions from {1,2,3,4,5} to {1,2,3}, is calculated as 3^5, while the subsets Ai have a size of 2^5 each, and intersections Ai∩Aj yield sizes of 1^5. The number of surjective functions is determined using Stirling numbers of the second kind, specifically S(5,3), which relates to partitioning the set into three non-empty subsets. The conversation highlights the importance of understanding how surjective functions correspond to partitions and suggests methods for counting these functions without relying solely on Stirling numbers.
Stephen88
Let A be the set of all functions f:{1,2,3,4,5}->{1,2,3} and for i=1,2,3 let Ai denote a subset of the functions f:{1,2,3,4,5}->{1,2,3}\i.
i)What is the size of :
1). A,
2).the sizes of its subsets Ai,and
3).Ai\capAj (i<j) also
4).A1\capA2\capA3.
ii)Find with justification the number of surjective functions f:{1,2,3,4,5}->{1,2,3}.
iii)Explain how each surjective function gives a 3-partiton of f:{1,2,3,4,5}
iv)How many 3-partitons of f:{1,2,3,4,5} are there altogethere?
Answers.
i)1).3^5...2).2^5 each 3).1^5 each...4).0
ii)We can use stirling numbers of the second kind to find this out S(5,3).
iii)Because the image of the function is made up of 3 elements?
iv)I don't know...I"m still thingking the same as for part ii)
hey Stephen88 can you clarify how the Ai subsets are defined? its not exactly clear to me in the question
Is Aj the subset of functions that only map
f \in A_i \iff f:{1,2,3,4,5}-&gt;{1,2,3}\i
so A_1 is given by
f \in A_1 \iff f:{1,2,3,4,5}-&gt;{2,3}
If so
1,2,3,4 look ok
so a surjective function is onto, meaning it must map at least one x to each y
ii) have to admit I didn't know about Stirling Numbers but googling a Stirling number of the second kind is exactly the way to partition n (5) objects into k (3) non-emtpy subset, which makes sense. As I've not used them explicitly I would be careful to check how repetitions are counted...as an example the partition:
1 | 2 | 345
could be expressed as 6 = 3! different surjective functions
Another way that may work is to count functions that are not surjective and subtract from the total number of functions
iii) partition the initial set based on image element, you could show that this gives an equivalence class an so a partition
iv) consider the point on counting in ii)
Question number ii) shouldn't be too hard to do without deriving the stirling formula of the second kind.
Try counting all surjections from X -> Y where X has a cardinality 1 greater than Y ( ex. X: {1,2,3,4} , Y : {1,2,3} ). This case should help you generalize into the case where the size of X is 2 greater than Y ( ex. X:{1,2,3,4,5} Y : {1,2,3} ) Make sure you account for "overcounts"
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
  • · Replies 27 ·
